RoadTest: Enroll to Review the Infineon AIROC™ Cloud Connectivity Manager Eval Kit
Author: swathic
Evaluation Type: Connectors & Cable
What other parts do you consider comparable to this product?: N/A
What were the biggest problems encountered?: Connecting the device as beginner for AWS cloud
In the present roadtest AIROC IFW956810 CCM evaluation kit is used to connect to AWS cloud for IoT application.
Initially out-of-box test is conducted as follows:
Quick Evaluation Flow
https://documentation.infineon.com/airoc-ccm/docs/quick-evaluation-flow
The IFW956810 CCM evaluation kit comes with a quick evaluation flow that lets you test your device right out of the box without creating an AWS account. The following steps will enable you to connect the kit to the internet through Wi-Fi and send random data points to the AWS staging account.
Connect the CCM module to your PC
Connect the IFW956810 Single-band Wi-Fi 4 Cloud Connectivity Manager evaluation kit to the PC using either the Type-C connector or Type-A male to Type-C female cable.
Steps for Quick Connect evaluation
Download the following quick connect package and extract Infineon-qc-utility.zip: https://quickconnectexpresslinkutility.s3.us-west-2.amazonaws.com/infineon/QuickConnect_infineon_v1.0.zip
Extract the utility package inside the Infineon-qc-utility folder with respect to your OS.
Connect the IFW956810 Single-band Wi-Fi 4 Cloud Connectivity Manager evaluation kit to the PC using either the Type-C connector or Type-A male to Type-C female cable and determine the serial port. To find the serial port of the device, please refer to section here .
Complete the details in the config.txt file to have the correct serial port, as well as Wi-Fi SSID and password.
Execute the executable in the quick connect package: run the Start_Quick_Connect.exe in the case of Windows OS, or in Linux and Mac, go inside the extracted folder.
Random values displayed in visualizer from IFW956810 CCM evaluation kit.
SEND message in AT command as "I am doing well with INFINEON Products by connecting to cloud".
Video Demo:
