PMODTMP2 Temperature Sensor and Thermostat Control - Review
Table of contents
RoadTest: PMODTMP2 Temperature Sensor and Thermostat Control
Author: s2000gt
What were the biggest problems encountered?:
The Digilent Pmod TMP2 (Revision B) is a temperature module allowing users to detect ambient temperatures ranging from -40 °C to 150 °C.
Features
  • 16-bit ambient temperature sensor
  • Typical accuracy better that 0.25 ºC
  • 240 ms continuous conversion time
  • Programmable over and under-temperature control pins
  • No calibration required
  • 2×4-pin connector with I2C interface
The Pmod TMP2 utilizes the Analog Devices ADT7420. Users may measure the ambient temperature at a default resolution of 0.0625 °C
I²C Address Selection
I²C Addresses
JP2JP1Device Address
OpenOpen0x4B (0b10001011)
OpenShorted0x4A (0b1001010)
ShortedOpen0x49 (0b1001001)
ShortedShorted0x48 (0b1001000)
Pinout Description Table
Header J1Jumper Blocks
PinSignalDescriptionJumper BlockStateDescription
1 & 5SCLSerial ClockJP1Open/ShortedAddress bit 0 high/low
2 & 6SDASerial DataJP2Open/ShortedAddress bit 1 high/low
3 & 7GNDPower Supply GroundUser Outputs
4 & 8VCCPositive Power SupplyHeader NamePin NameDescription
J2CTCritical Threshold Output
J3INTInterrupt Output
Test Setup
Example Code
* Test of Pmod TMP2
* Description: Pmod_TMP2
* The ambient temperature is displayed on the serial monitor.
#include  // call library
#define ADT7420_Address 0x4B // I2C address of the Pmod TMP2
int MSB;
int LSB;
int value;
float temperature;
void setup()
 Serial.begin(9600); // initialization of serial communication
 Wire.begin(); // initialization of I2C communication
 Init_ADT7420(); // initialization of Pmod TMP2 module
void loop()
 Wire.beginTransmission(ADT7420_Address); // Begin measurement
  Wire.endTransmission();
 delay(10);
 Wire.requestFrom(ADT7420_Address, 2); // Recovery of the two bytes MSB and LSB
 if(Wire.available() <=2)
  MSB = Wire.read();
  LSB = Wire.read();
 value=(MSB<<8)|LSB ;
 if (((value>>15)&1)==0) // If the temperature is positive
  temperature=value/128.0;
 else // If the temperature is negative
  temperature=(value-65535)/128.0;
 Serial.print("MSB="); // display in serial monitor
 Serial.println(MSB);
 Serial.print("LSB=");
 Serial.println(LSB);
 Serial.print("Value=");
 Serial.println(value);
 Serial.print("Temperature=");
 Serial.print(temperature);
 Serial.println(" C");
 Serial.println();
 delay(3000);
// Initialization of Pmod TMP2 module
void Init_ADT7420(void)
// Configuring the ADT7420 in 16 bit mode
 Wire.write(0x03);
 Wire.write(0x80);
Code Execution
Conclusion
The Pmod series of modules are nice easy way to interface a wide variety of devices to your microcontroller project.
They cover SPI, I2C, GPIO and UART and conform to Digilents Pmod interface standard.
While most development board do not come with a Pmod connector, it's easy enough to wire one up.
The TMP2 module seems to be a very accurate and capable module.
  • I've always liked units that cover a wide temperature variation and don't need calibration.
    In the past I've stuck with the DS18B20 range, but they require One Wire, while I2C would be much more useful at times.
    The time to get a reading is very quick comapred with the Dallas range.
    I presume checking the accuracy was difficult.
    Cheers
    Cheers
