Pocket Beagle - Review
Table of contents
RoadTest: Pocket Beagle
Author: mnitin59
What other parts do you consider comparable to this product?: Raspberry pi Zero, ATTiny
What were the biggest problems encountered?: Hardware design and the I/O Ports, Pin Configuration
Product Unboxing
I'm very thankful to Element 14 community for giving me the opportunity for reviewing Pocketbeagle Hardware. I have received this hardware within 8 days of getting selected for this road test.
The parcel box was very good in condition and kept with safety wrappers which felt nice and helpful. I check with the Board packing it was very awesome and attractive for hardware hobbyist which for getting a mini-computer for managing all kind of work task in daily life.
Fig 1.1 Parcel Box
Fig 1.2 Unboxing Box
Fig 1.3 Upside view of the Box
Fig 1.4 Wrapping out the PocketBeagle Hardware
Fig 1.5 Backside view of the cover board
Fig 1.6 Front Side view of the PocketBeagle Box
Hardware Review
The PocketBeagle is very awesome hardware for developing an interactive project in electronics and smart devices. The setup for this hardware is very easy and its plug and play device.
The webpage gets configured and help to command on I/O port to control and get the sensor data.
Technical Review:
SpecificationRating (5)
Electronics assembly4
Interconnection track4
Component Selection5
Optimization in design3
Connectivity and networking5
Conclusion
The PocketBeagle is Awesome hardware as it can be used in any project and help to reduce complexity for the day-to-day problems. Even it's useful for makers, engineers, and developers to use it for innovative use in projects like robotics, communication, IoT, etc.
  • OK, nice overview of the device, but what types of tests did you perform and where are your test results?
    How does it compare in processing power to the RPI?
    How well does it transfer data from I/O pins to memory and from memory to I/O.
    How many timers can you set up and how stable and accurate are they?
    What are the timing delays introduced by the operating system verses direct I/O manipulation?
    There are a lot of things to test on this board. I hope you do a few of them to give us a real test report.
