Raspberry Pi 3 in a Box - Review
Table of contents
RoadTest: Raspberry Pi 3 in a Box
Author: ddip214
What were the biggest problems encountered?: The biggest issue I encountered was an issue with the SD card, for some reason I was unable to use it. Luckily I have tons of them around the house so I installed Raspbian
Deluxe Raspberry Pi3 Starter Kit
Roadtest Review
David DiPonzio
May 2020
What is included in this kit?image
Kit Contents:
     • Raspberry Pi3 Model B
     • 8GB microSD card and SD adapter, preloaded with the NOOBS OS
     • Official red and white Pi 3 case
     • Multi-regional 2.5A power supply
     • 1m HDMI cable
     • Official USB optical mouse
     • Official scissor-switch action USB keyboard
     • “Adventures in Raspberry Pi” guide book
Shipping:
The kit came properly shipped with bubble wrap and other protective measures.
When opening the box I was met with a beautiful white box containing the Pi and the rest of the contents.
Setup:
The setup was extremely easy, which is why Raspberry Pi's are becoming so popular. You can set it up anywhere, on a desk, on a shelf, anywhere. The learning curve is relatively easy and the user gets to decide how in-depth he or she wants to explore.
Thoughts on the Kit:
The kit is a great beginner kit, the price is right for the number of devices included. The purchaser has everything but a screen to get started. As for the book included in the kit (yes it is a little outdated) but for starters and young children is a great way to learn the basics and build a solid foundation in Python. I thought the mouse was well constructed and felt great in my hand during use. The keyboard is sleek and well built. I wish these input devices were wireless though. The case for the Raspberry Pi is beautiful, I love the red and white color scheme. When built the case feels very durable, and protected. There were also several different plug types for different nations.
Issues with the Kit:
The only issue I came across was the SD card. This is apparent in other tester's reviews also. I have several micro SD cards so I installed Raspbian on one of them.
What am I doing with my Pi:
I have dedicated my Pi to track airplanes through Flightradar24.com. I have purchased a USB ADS-B receiver to plug into my Raspberry Pi. So far I have tracked over 218 aircraft. I plan on running this system for some time. If anyone is interested my station name is: T-KROC55.
  • , it's good to go into detail, and here's some information I'd be interested in your opinion on with this hardware:
    - What's the key pressing on the keyboard like?
    o Is it similar to a mechanical keyboard, or perhaps more like a laptop?
    o Do you have to spend much effort to press the keys?
    o Are there any problems with bouncing on them?
    o How does the plastic of them feel? Good quality or poor?
    - How's the mouse?
    o Do you have to do a lot of effort with settings for mouse sensitivity?
    o Does it have any problems or issues on multiple surfaces? What surfaces have you tried?
    - How's the power supply?
    o Do you get any brownout warnings with it supplied?
    o Does it seem to throttle the performance of the hardware at all?
    - How's the Raspberry Pi?
    o Does it perform as well as you'd hope?
    o Does it overheat in the Pi Case you're using for the applications you're using it for?
    o Did you have any difficulties in setting it up or putting it into the case housing?
    - What's the book like?
    o Does it pace itself well?
    o Does it read clearly?
    o Did you do any projects from it, follow through with it?
    o Were there many errors or problems with following the book?
    - How's the SDCard?
    o What class is it?
    o Are there any performance limitations?
    o What software does it come with?
    - What do you need for your applications?
    o You've setup with FlightRadar, what internet connection do you need?
    o Does it need to always be on? Can you disconnect?
    o What does it give you? What're the benefits?
    o Do you have your Pi doing anything else while it's doing that?
    o How're you going to expand on that project?
    o How do the applications you've chosen use the rest of the hardware given in the kit? If not, why use it for that application?
    This would be a good amount of detail to enter for a review image
  • Dubbie,
    I downloaded the OS from flightradar24 and followed the steps here: https://www.flightradar24.com/build-your-own
    I also purchased an ADS-B receiver to plug into the Raspberry pi. https://www.amazon.com/gp/product/B009U7WZCA/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    Once I got everything set up it started feeding data to flightradar. Very simple.
  • David,
    I am interested in details of the application. I have a Raspberry Pi already.
    Dubbie
  • The detail in regard to the application? Or the kit?
  • I recommend this kit. The devices provided are of high quality in my opinion. I was able to hook up everything provided to my TV set.
  • Can you provide us with an assessment of the quality of the items provided, such as the keyboard, mouse and physical components?
    I look forward to seeing the results of your long term project, but I think many members would like to know if the basic kit is worth the money.
  • It is very nice packaging. Looks an interesting application. Is there any more detail?
    Dubbie
