RoadTests & Reviews
RoadTests & Reviews
Documents “dmesg” with Raspberry Pi Model B Rev 2
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Author Author: MARK2011
  • Date Created: 11 Jun 2019 12:21 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:01 PM
  • Views 3293 views
results of dmesg with Raspberry Pi Model B Rev 2
(Raspberry Pi Model B Rev 2 roadtest)
https://www.element14.com/community/roadTestReviews/2951/l/new-years-grab-bag-roadtest-review
pi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.79+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1159 Sun Nov 4 17:28:08 GMT 2018
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt: Machine model:
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 8 MiB at 0x1b400000
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c09c6650, node_mem_map db010000
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=5600e06f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 435232K/458752K available (6435K kernel code, 588K rwdata, 1992K rodata, 444K init, 673K bss, 15328K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   ( 4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
                   lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
                   modules : 0xbf000000 - 0xc0000000   ( 16 MB)
                     .text : 0xc0008000 - 0xc0650e90   (6436 kB)
                     .init : 0xc08cf000 - 0xc093e000   ( 444 kB)
                     .data : 0xc093e000 - 0xc09d1000   ( 588 kB)
                      .bss : 0xc09d6904 - 0xc0a7eeac   ( 674 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 24117 entries in 71 pages
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000033] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000065] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000150] bcm2835: system timer (irq = 27)
[    0.000714] Console: colour dummy device 80x30
[    0.000740] console [tty1] enabled
[    0.000774] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060300] pid_max: default: 32768 minimum: 301
[    0.060795] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060814] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062097] Disabling memory control group subsystem
[    0.062254] CPU: Testing write buffer coherency: ok
[    0.063379] Setting up static identity map for 0x8200 - 0x8238
[    0.064615] devtmpfs: initialized
[    0.073956] random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
[    0.074901] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.075299] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.075326] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.076646] pinctrl core: initialized pinctrl subsystem
[    0.077966] NET: Registered protocol family 16
[    0.081001] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.087339] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.087356] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.087472] Serial: AMBA PL011 UART driver
[    0.090235] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.129863] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[    0.132214] SCSI subsystem initialized
[    0.132431] usbcore: registered new interface driver usbfs
[    0.132525] usbcore: registered new interface driver hub
[    0.132725] usbcore: registered new device driver usb
[    0.140816] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-11-04 16:31
[    0.142884] clocksource: Switched to clocksource timer
[    0.231627] VFS: Disk quotas dquot_6.6.0
[    0.231748] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.232048] FS-Cache: Loaded
[    0.232371] CacheFiles: Loaded
[    0.249472] NET: Registered protocol family 2
[    0.250660] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.250749] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.250844] TCP: Hash tables configured (established 4096 bind 4096)
[    0.250993] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.251023] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.251365] NET: Registered protocol family 1
[    0.252077] RPC: Registered named UNIX socket transport module.
[    0.252089] RPC: Registered udp transport module.
[    0.252094] RPC: Registered tcp transport module.
[    0.252099] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.254173] hw perfevents: no irqs for PMU, sampling events not supported
[    0.254251] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.257907] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.269931] FS-Cache: Netfs 'nfs' registered for caching
[    0.271252] NFS: Registering the id_resolver key type
[    0.271306] Key type id_resolver registered
[    0.271314] Key type id_legacy registered
[    0.271341] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.276077] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.276490] io scheduler noop registered
[    0.276504] io scheduler deadline registered (default)
[    0.277036] io scheduler cfq registered
[    0.277050] io scheduler mq-deadline registered
[    0.277057] io scheduler kyber registered
[    0.279331] BCM2708FB: allocated DMA memory 5b500000
[    0.279393] BCM2708FB: allocated DMA channel 0 @ dc80d000
[    0.305210] Console: switching to colour frame buffer device 170x48
[    0.326877] bcm2835-rng 20104000.rng: hwrng registered
[    0.327103] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.328187] vc-sm: Videocore shared memory driver
[    0.328810] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    0.348569] brd: module loaded
[    0.361225] loop: module loaded
[    0.361249] Loading iSCSI transport class v2.0-870.
[    0.362141] usbcore: registered new interface driver smsc95xx
[    0.362175] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.390280] dwc_otg 20980000.usb: base=0xf0980000
[    0.590622] Core Release: 2.80a
[    0.590641] Setting default values for core params
[    0.590679] Finished setting default values for core params
[    0.791041] Using Buffer DMA mode
[    0.791058] Periodic Transfer Interrupt Enhancement - disabled
[    0.791063] Multiprocessor Interrupt Enhancement - disabled
[    0.791076] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.791184] Dedicated Tx FIFOs mode
[    0.792100] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[    0.792130] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.792143] dwc_otg: Microframe scheduler enabled
[    0.792321] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc049c7ac
[    0.792338] WARN::hcd_init_fiq:460: FIQ ASM at 0xc049ca88 length 36
[    0.792367] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[    0.792460] dwc_otg 20980000.usb: DWC OTG Controller
[    0.792526] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.792605] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.792660] Init: Port Power? op_state=1
[    0.792668] Init: Power Port (0)
[    0.793202] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.793222] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.793234] usb usb1: Product: DWC OTG Controller
[    0.793243] usb usb1: Manufacturer: Linux 4.14.79+ dwc_otg_hcd
[    0.793254] usb usb1: SerialNumber: 20980000.usb
[    0.794391] hub 1-0:1.0: USB hub found
[    0.794490] hub 1-0:1.0: 1 port detected
[    0.795516] dwc_otg: FIQ enabled
[    0.795528] dwc_otg: NAK holdoff enabled
[    0.795535] dwc_otg: FIQ split-transaction FSM enabled
[    0.795554] Module dwc_common_port init
[    0.796135] usbcore: registered new interface driver usb-storage
[    0.796585] mousedev: PS/2 mouse device common for all mice
[    0.796648] IR NEC protocol handler initialized
[    0.796655] IR RC5(x/sz) protocol handler initialized
[    0.796660] IR RC6 protocol handler initialized
[    0.796665] IR JVC protocol handler initialized
[    0.796672] IR Sony protocol handler initialized
[    0.796677] IR SANYO protocol handler initialized
[    0.796682] IR Sharp protocol handler initialized
[    0.796687] IR MCE Keyboard/mouse protocol handler initialized
[    0.796692] IR XMP protocol handler initialized
[    0.798004] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.798561] bcm2835-cpufreq: min=700000 max=700000
[    0.799186] sdhci: Secure Digital Host Controller Interface driver
[    0.799196] sdhci: Copyright(c) Pierre Ossman
[    0.799850] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[    0.800058] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.800637] ledtrig-cpu: registered to indicate activity on CPUs
[    0.800788] hidraw: raw HID events driver (C) Jiri Kosina
[    0.801057] usbcore: registered new interface driver usbhid
[    0.801066] usbhid: USB HID core driver
[    0.802029] vchiq: vchiq_init_state: slot_zero = db580000, is_master = 0
[    0.804270] [vc_sm_connected_init]: start
[    0.814723] [vc_sm_connected_init]: end - returning 0
[    0.815768] Initializing XFRM netlink socket
[    0.815830] NET: Registered protocol family 17
[    0.815998] Key type dns_resolver registered
[    0.817914] registered taskstats version 1
[    0.826424] uart-pl011 20201000.serial: cts_event_workaround enabled
[    0.826568] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.826676] console [ttyAMA0] enabled
[    0.830198] sdhost: log_buf @ db513000 (5b513000)
[    0.902960] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.904254] of_cfs_init
[    0.904430] of_cfs_init: OK
[    0.905459] Waiting for root device PARTUUID=5600e06f-02...
[    0.935217] random: fast init done
[    1.013167] Indeed it is in host mode hprt0 = 00021501
[    1.084494] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.087941] mmc0: new high speed SDHC card at address aaaa
[    1.089004] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    1.092864]  mmcblk0: p1 p2
[    1.120575] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.120692] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.130110] devtmpfs: mounted
[    1.133025] Freeing unused kernel memory: 444K
[    1.133036] This architecture does not have kernel memory protection.
[    1.223020] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.223264] Indeed it is in host mode hprt0 = 00001101
[    1.463793] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    1.463840] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.465153] hub 1-1:1.0: USB hub found
[    1.465352] hub 1-1:1.0: 3 ports detected
[    1.692637] systemd[1]: System time before build time, advancing clock.
[    1.783005] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.843742] NET: Registered protocol family 10
[    1.845731] Segment Routing with IPv6
[    1.861390] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.888592] random: systemd: uninitialized urandom read (16 bytes read)
[    1.898114] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    1.899288] systemd[1]: Detected architecture arm.
[    1.902968] systemd[1]: Set hostname to <raspberrypi>.
[    1.913567] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    1.913593] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.917128] smsc95xx v1.0.6
[    1.993165] random: systemd: uninitialized urandom read (16 bytes read)
[    2.015530] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:aa:7e:d4
[    2.113095] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[    2.241618] uart-pl011 20201000.serial: no DMA platform data
[    2.252339] usb 1-1.2: New USB device found, idVendor=15ca, idProduct=00c3
[    2.252365] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.252377] usb 1-1.2: Product: USB Optical Mouse
[    2.275663] input: USB Optical Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:15CA:00C3.0001/input/input0
[    2.276383] hid-generic 0003:15CA:00C3.0001: input,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-20980000.usb-1.2/input0
[    2.307591] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[    2.373069] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[    2.605474] usb 1-1.3: New USB device found, idVendor=1241, idProduct=1503
[    2.605499] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.605511] usb 1-1.3: Product: USB Keyboard
[    2.605521] usb 1-1.3: Manufacturer:
[    2.656887] input:   USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1241:1503.0002/input/input1
[    2.724200] hid-generic 0003:1241:1503.0002: input,hidraw1: USB HID v1.10 Keyboard [  USB Keyboard] on usb-20980000.usb-1.3/input0
[    2.797946] input:   USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1241:1503.0003/input/input2
[    2.863500] hid-generic 0003:1241:1503.0003: input,hidraw2: USB HID v1.10 Device [  USB Keyboard] on usb-20980000.usb-1.3/input1
[    3.117884] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.119645] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.120683] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.148831] systemd[1]: Created slice User and Session Slice.
[    3.151133] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.151956] systemd[1]: Listening on udev Kernel Socket.
[    3.152719] systemd[1]: Listening on Syslog Socket.
[    3.865956] i2c /dev entries driver
[    5.918248] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.494783] systemd-journald[66]: Received request to flush runtime journal from PID 1
[    9.983695] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[   10.093335] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[   12.933093] random: crng init done
[   12.933120] random: 7 urandom warning(s) missed due to ratelimiting
[   16.670878] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   19.432099] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   21.012814] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[   33.562503] fuse init (API version 7.26)
[ 3197.282448] bash (929): drop_caches: 3
[ 3929.592057] bash (17174): drop_caches: 3
  • dmesg
  • raspberry pi model b
  • colporteur
    colporteur over 6 years ago +1
    Hummmm... radio check. Did I miss the part of the conversation that indicates the intent of this post? Sean
  • colporteur
    colporteur over 6 years ago in reply to MARK2011 +1
    No problem fellow RoadTest traveler, it happens to me. I just am attracted by bright shiny objects or Raspberry Pi's posts. A dmesg entry is like a fishing hook baited with a juicy fat night crawler. I…
  • colporteur
    Sean
  • colporteur
    Sean
  • MARK2011
    MARK2011 over 6 years ago in reply to colporteur
    thank you for the remark!
    my apologize!
    The story is relative simple - I have still hesitations with final publishing of report, concerning the test of the old raspberry.
    I just wanted to show results of dmesg but published it before the main document - I admit,  my fault!
    Marek
  • colporteur
    I just am attracted by bright shiny objects or Raspberry Pi's posts. A dmesg entry is like a fishing hook baited with a juicy fat night crawler. I looked at the post and spit the hook out. No context on content, so I just moved on. Good luck.
    Sean
