    Members
    • Avnet Boards Community
    • Choose Another Store
3D Printing
3D Printing
Documents 3D Printing Wishlist and Giveaway - What do I need to begin 3D Printing?
3D Printing requires membership for participation - click to join
  • Author Author: mcollinge
  • Date Created: 20 Oct 2021 2:54 PM Date Created
  • Last Updated Last Updated: 2 Mar 2022 9:30 AM
  • Views 9795 views
  • Comments 18 comments
3D Printing Wish List and Give Away!
One of the coolest technologies to emerge in the last decade is 3D printing. 3D printers are incredibly versatile tools that can print virtually anything you need. The technology has improved by leaps and bounds since its inception, and incredibly accurate, high resolution 3D prints can now be made pretty inexpensively.
We've put together a wish list with all the fundamental items needed to set you up for a life in 3D Printing
3D Printing Giveaway
3D Printing Giveaway Prizes
  • Dremel starter tool kit
  • Selection of Multicomp PLA 3D Printing Filament.
Questions:
1) What's the first thing you're going to print and why?
2) What are we missing from this list?  Any special tools/procedures/secrets that you use to get the best 3D prints?
Terms:
Post your answer as a comment below between 4th November 2021 and 4th December 2021.
The best answers will be chosen by the element14 community team, and you will be shipped your prize (or local equivalent) free of charge.
3D printers
Let's start with the 3d printer itself. There is a wide range to choose from. Select based on what you want to print, your skill level, the materials you want to print with, the size of the prints you want to make, and most importantly, budget. Whether you're printing industrial parts for machine automation or little knick-knacks to decorate your desk, there's a 3D printer for you.
Flashforge Creator Pro
Creality CR10 MAX
Ultimaker S3
Glue stick
In order to create a great 3D print, build plate adhesion is extremely important. If your print won't stay still, accuracy will suffer. Hairspray is popular for adhesion, but glue is more precise and creates less of a mess.
Magigoo Glue Stick
Deburring tool
Many 3D prints end up with small pieces of protruding plastic that have to be cleaned up. A deburring tool makes the process easier, and with less chance of screwing up and destroying your print. Deburring tools are especially good for cleaning up modeled holes.
Ruko Deburring Tool
Pliers
Pliers are useful on any bench, and 3D printing is no exception. Use your pliers for print core maintenance, repairs, or removing support material.
Flat Nosed Pliers
Masking Tape
Masking tape is incredibly versatile in 3D printing. Add it to the print bed to protect it from scratches and to help 3D prints adhere. Heat resistant masking tape is preferred for heated beds.
Masking Tape
Dremel
Dremels make smoothing a lot easier, but be careful! A Dremel can get hot, and material like PLA can melt. The sanding attachments work well, but keep those RPMs low.
Product Link
Different sized Nozzles
Grab a variety of nozzles for your 3D printer. Larger ones can print faster at the expense of resolution. Smaller ones can print with more detail, but are slower.
These are examples for Ultimaker 3D printers.
0.4mm
0.4mm Nozzles
0.8mm
0.8mm Nozzles
Filament
Don't forget to stock up on filaments in a variety of colors, including the shiny and translucent ones.
Multicomp Silver PLA Filament
Measuring Tools
Measuring tools are required for checking machine setup and print accuracy. You've probably already got a nice ruler, but adding something like digital calipers will take your accuracy to a new level.
Digital Calipers
Raspberry Pi to run OctoPrint.
OctoPrint (https://octoprint.org) is software that can control and monitor every aspect of your 3D printer from within a browser. You can do things like viewing a webcam feed of your print, monitor temperatures, or start/stop/pause the current print job. It's completely free. OctoPrint is also open source, and there are already a bunch of plugins from 3rd party developers available for it.
Raspberry Pi 4 Starter Kit
How to 3D Print Webinar Series
Watch our 4 Part Webinar Series on 3D Printing on demand. We'll take you from your first print to designing prototypes.
Introduction to 3D Printing
Create your own 3D Models
Maintenance and Diagnosing Bad Prints
First Print Basics
Questions:
Terms:
  • 3d printer giveaway
  • 3dprinting
  • 3dprintin
  • 3d print
  • qbytes.dq
    qbytes.dq 7 months ago +10
    I would print a flow rate square.  After printing, I would calculate my flow rate and update my Extrusion Multiplier (you should do this for…
  • Fred27
    Fred27 7 months ago +1
    1) I've bought a couple of printers over the last couple of years - an Anycubic Photon resin printer and a Creality Ender 3 to replace a very old FDM printer that broke. One of the first things I printed…
  • fmilburn
    fmilburn 7 months ago +1
    3D printers don’t make precise holes, especially on vertical sides, so a drill and bits / step bits are useful.  A pin vise and small set of bits works well for small holes. I now use 3mm heat set threaded…
  • perx000
    perx000 7 months ago
    1)What's the first thing you're going to print and why?
    I would like to 3D print neoprene seal to utilize it in my profession as a plumber
    user's guide I guess
    • Up 0 Down
    • Reply
  • rsjawale24
    rsjawale24 7 months ago
    I would 3D print antennas!!
    Yes! You read it correct. 3D printed antennas are gaining popularity among researchers and there already are multiple papers published on 3D printed antennas and other electronic devices.
    Since, my area of research is Antennas, I would like to 3D print one, (might as well fetch me a good paper publication ).
    So, the way this is done is, instead of using conventional substrates like FR-4, RO4350B, etc for antennas, an artificial dielectric medium can be printed using a 3D printer and later it can be coated with conductive inks to get a working antenna.
    Not just antennas, but even microwave lenses for focusing microwave beams are being 3D printed nowadays. Quite an interesting application!
    What's missing from the list?
    1. Though the list has a dremel rotary tool, sometimes a sandpaper comes in handy where manual polishing is required.
    2. A surgical blade/sharp knife for cutting any leftover material from the edges of the print.
    3. Lastly, a hot wire cutter and a soldering iron for smooth finishes and create holes in the 3D printed design for holding nuts for screws (in case of enclosures, etc).
    • Up +1 Down
    • Reply
  • ntewinkel
    ntewinkel 7 months ago
    My first next thing to print will most likely be custom enclosures for sensor projects I'm working on.
    It could also be an artsy frame for my wife's projects.
    Missing from the list is definitely the precision side-cutters, as I often need to snip the filament a certain way to get it started in the printer.
    Maybe also a spatula/scraper to help pop the print off the bed.
    • Up 0 Down
    • Reply
    dougw 7 months ago in reply to colporteur
    Good choices colporteur That style of craft knife is by far the most useful tool in 3D printing. Lots of blades are needed as PLA will dull the blades quite quickly. The flush side cutters would be the next most useful, followed by a sharp edged putty knife for removing prints form beds. Other useful items are a sanding block, files, a rubber jaw vise, a nozzle spanner and a chisel. Has anyone ever found a set of rubber-jawed vise grip pliers?
    I don't "need" another 3D printer right now, but filament and 3D printing accessories are always useful.
    One of my bucket list of printer projects is to design and build a filament spool holder that will prevent all tangles and jamming of filament on the spool. The most common cause for my prints to fail is a filament jam on the spool. It doesn't happen on every spool, but needless to say, encountering a jam near the end of a long unattended print can be vey disappointing. When the filament coming off gets gets caught under another layer that loosened off, puling on the filament just tightens the "knot" and the filament can no longer come off the reel. This is a glaring gap in 3D printer technology offerings - they don't even have an alarm or automatic pause when a knot happens.
    • Up +1 Down
    • Reply
  • colporteur
    colporteur 7 months ago
    3D printing for me would be enclosures. Small unique boxes to fit electronic projects.
    I'm frustrated having to spend money on project boxes. I never find one that fits just right. I usually have to find something that is close and live with it.
    I dream of a selection of box templates of different sizes. Length, width and depth are all customisation. The cover is four screw minimum at the corners and for boxes of greater length the option to add additional holes. Inside the box you can conveniently position mounting holes to secure a printed circuit board of point to secure a cable tie.
    If I was to purchase a 3D printer I suspect there would be a proliferation of boxes of all shapes and sizes.
    Since I have no experience with 3D printing, I'm pitching two tools I find extremely useful when working with plastic models. I have also had reason to use them on 3D printed items I have ordered online. The Exacto Knife and sidecutters.  They are great for extracting items and cleaning of any small plastic burrs.
    • Up +1 Down
    • Reply
  • fmilburn
    3D printers don’t make precise holes, especially on vertical sides, so a drill and bits / step bits are useful.  A pin vise and small set of bits works well for small holes. I now use 3mm heat set threaded inserts on builds that need to be taken apart and reassembled frequently.  And from time to time it is necessary to glue parts. For that I prefer two part epoxy for the strength.
    • Up +1 Down
    • Reply
  • Fred27
    Fred27 7 months ago
    1) I've bought a couple of printers over the last couple of years - an Anycubic Photon resin printer and a Creality Ender 3 to replace a very old FDM printer that broke. One of the first things I printed was a gear bearing. I find it's a good test of a printer's capabilities and it's an interesting fidget spinner style desk trinket. It also prompts questions from people who aren't familiar with 3D printing. It's interesting as it would be impossible to create any other way. The cogs are free to move but permanently captured by nature of their herringbone design.
    2) One things that seems to get forgotten in the world fo 3D printing is how to create the STL files for the thing syou're going to print. Sure - some people might be happy downloading things from Thingiverse and printing someone else's design, but there comes a point where you need to create something unique. There's a huge range of options depending on what you're trying to do. If you're making an artistic sculpture there's products like ZBrush. For a more CAD-like process there's Fusion360 which also works well alongside Eagle PCB design. I'm a coder, so I feel more comfortable with a scripted tool like OpenSCAD. There's no right tool for 3D printing as they are all aimed at a different process. It i simportant to get a feel for what one suits your style and the object you're trying to create.
    • Up +1 Down
    • Reply
  • glennvanderveer
    glennvanderveer 7 months ago
    The first thing I am going to print is a case for my Android Auto Pi4 display.
    One tool(s) missing is a scraper. Sometimes no matter how much bed preparation you do, you need to carefully scrape you part off the bed...
    • Up 0 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
