Ask an Expert Forum help with the flow sensor FS5
  • Replies 22 replies
  • Subscribers 318 subscribers
  • Views 3971 views
See a helpful answer?
hi please i need help how to use my flow sensor FS5.
would like to measure flow of gas so i bought the FS5 but now i am reading the datasheet that i download from the webside but its not helping.
if anyone have use it befor can i have your circuit diagram please.
Regards
    dougw over 11 years ago +2
    Hi Leonel, A reference circuit is included in the data sheet: http://www.farnell.com/datasheets/484569.pdf You may need to reduce or offset the output voltage. Here is a link to an example: http://dl.dropboxusercontent…
    dougw over 11 years ago in reply to Former Member +2
    Hi Leonel, The sensor includes the heater (Rs is the Sensor Resistance and RH is the heater resistance in the circuit - both of these resistors are stuck together as part of the sensor you have). One wire…
    Former Member over 11 years ago in reply to dougw +1
    hi Doug Thanks for your response. I saw the 2nd link in your response.I can see circuit diagram its exactly something like that that am looking for but have a concern: Its written sensor is it the FS5…
    dougw over 7 years ago in reply to saeed.lanjekar
    In a 5 pin op-amp 2 pins are for power (supply voltage and ground)
  • usmanshahid001.us
    usmanshahid001.us over 6 years ago in reply to dougw
    please send me any link where from to buy it.thanks in advance
