SCHURTER presents the new, compact, high grade EMI- Filter, FMBB NEO series for one phase systems. Three variations of 2-stage filter designs allow specific selection of FMBB NEO filter products for efficient EMI solutions.
The new FMBB NEO Filter series consists of 3 different compact 2-stage filter designs. The 3 filter designs (Design C, Design D and Design F) are characterised by a high symmetrical and asymmetrical attenuation. The FMBB NEO filter Design C attenuates potentially strong conducted interferences. Design D is constructed for the attenuation of high frequency interferences, whereas the Design F is designed more for low frequency noise attenuation. All designs come with high insertion loss performance. The FMBB NEO one phase filter is designed with a 250 VAC filter at a rated current of 1-36 A according to IEC and 125/250 VAC, 1-30 A according to UL/CSA. The connection to the filter is made with quick connect terminals or with bolts and nuts (M4). Optional flexible wire leads are available on request.
The compact NEO designed EMI-Filter is intended for use in industrial applications such as frequency converters, stepper motors, UPS-systems and current converters. On request, medical versions with leakage currents of < 80μA (M80) and < 5μA (M5) respectively are available. The series is ENEC and cURus approved and is qualified for use in equipment according to IEC/EN standard 60950.
Technical Features:
- One phase EMI-Line Filter according to IEC60939 and UL1283 available in 3 designs (design C/D/F)
- Current ratings: 1-36 A at 250 VAC (ENEC) or 1-30 A at 125/250 VAC (UL/CSA)
- Quick connect terminals / bolt and nut M4 terminals / flexible wire leads optional
- Standard or medical version M5 or M80
- Screw-on chassis mounting from top
Resources:
data sheet FMBB NEO http://www.schurter.ch/var/schurter/storage/ilcatalogue/files/document/datasheet/en/pdf/typ_FMBB_NEO.pdf
Single Phase Block Filters http://www.schurter.ch/en/Products/EMC-Products/Single-Phase-Block-Filters
About SCHURTER Group
The SCHURTER Group is headquartered in Lucerne (Switzerland) since 1933. SCHURTER is an internationally leading innovator and manufacturer of fuses, connectors, circuit breakers, input systems and EMC products as well as a PCB assembly service provider. Our industries span telecommunications, IT, medical and measurement technology sectors, emerging food & beverage and alternative energy industries. The major country-specific certifications including VDE, ENEC, UL, CSA, CCC, METI or KTL are evidence of our high quality and absolute reliability in each product.
Contact: info@schurter.com.sg
Website: www.schurter.com
