Graphene could be used in cordless tools, providing more run time and improved efficiency. (Image Credit: seagul/pixabay)
Most of us own cordless tools, and these have improved due to lightweight, advanced, and smaller batteries. For example, we've seen the capacity of lithium-ion batteries gradually increase, extending a device's operating time on a single charge. Graphene joined the game and is already being used in cordless tool batteries, making them more efficient than before. Because it's a new material, it costs nearly double compared to lithium-ion batteries.
One of the advantages of Graphene is that it's highly conductive (100x more than copper). So, by using it with a lithium-ion battery, we can see the charging time significantly decrease. Users won't need as many batteries since charging doesn't take too long — perfect for big projects. Moreover, the heat-resistant quality ensures that graphene batteries won't overheat.
However, one takeaway is that it discharges faster, too. This means graphene-based batteries could yield sufficient power for power-hungry tools like a concrete drill or chainsaw running for over an hour. Also, users can work on a project for hours at a time, thanks to Graphene's efficiency improvement.
So far, only CAT manufactures Graphene battery-based tools and sells an 18V graphene battery for $169.99. It's important to note that users need a CAT cordless tool to use it. The CAT 1 For All system works with this battery technology, which means many CAT tools are already compatible with a graphene battery. If owners don't have the appropriate tool, they'll need to buy one that's compatible with CAT's graphene batteries.
We can expect to see Graphene's popularity boost with more advancements, allowing other brands to use the tech with cordless tools. But that should happen in due time as companies are developing graphene batteries for such tools. And the price could drop once this battery technology becomes widely available.
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
kmikemoo
in reply to DAB
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
kmikemoo
in reply to DAB
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
