      • Japan
      • Vietnam
Robotics
Robotics
Blog ROS2 Learning Series - Blog 6 - Advanced Programming - Part 1
  • Author Author: crisdeodates
  • Date Created: 13 Apr 2024 5:35 PM Date Created
  • Views 1091 views
  • Robot operating System
  • robotics
  • ROS2
  • ROS
crisdeodates
crisdeodates
13 Apr 2024
ROS2 Camera Stream Project
Previously we got some basic insight on how to program ROS2 nodes and services. Now let us take a step further in ROS2 programming.
We will create a publisher node to capture a video stream from a camera and publish it to a topic.
We will also create a subscriber node who will subscribe to the camera stream topic and display it in an OpenCV window.
Install the OpenCV dependencies.
$ pip install opencv-python
Create a new ROS2 package with dependencies.
$ cd ~/ros2_ws/src
$ ros2 pkg create --build-type ament_python camera_stream --dependencies rclpy image_transport cv_bridge sensor_msgs std_msgs opencv-python
Create the camera_stream_publisher.py file and populate it with the following code:
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
from cv_bridge import CvBridge
import cv2
class CameraStreamPub(Node):
   Create a CameraStreamPub class, which is a subclass of the Node class.
   def __init__(self):
       Class constructor to set up the node.
       # Initiate the Node class's constructor and give it a name.
       super().__init__('camera_stream_pub')
       # Create the publisher. This publisher will publish an Image
       # to the video_frame_data topic. The queue size is 10 messages.
       self.publisher_ = self.create_publisher(Image, 'video_frame_data', 10)
       # We will publish a message every 0.1 seconds.
       timer_period = 0.1 # seconds
       # Create the timer.
       self.timer = self.create_timer(timer_period, self.timer_callback)
       # Create a VideoCapture object.
       # The argument '0' gets the default webcam.
       self.cap = cv2.VideoCapture(0)
       # Used to convert between ROS and OpenCV images.
       self.br = CvBridge()
   def timer_callback(self):
       Callback function.
       This function gets called every 0.1 seconds.
       # Capture frame-by-frame.
       # This method returns True/False as well
       # as the video frame.
       ret, frame = self.cap.read()
       if ret == True:
           # Publish the image.
           # The 'cv2_to_imgmsg' method converts an OpenCV
           # image to a ROS 2 image message.
           self.publisher_.publish(self.br.cv2_to_imgmsg(frame))
def main(args=None):
   Main function to initialize the node and start the camera stream publisher.
   # Initialize the rclpy library.
   rclpy.init(args=args)
   # Create the node.
   camera_stream_publisher_node = CameraStreamPub()
   # Spin the node so the callback function is called.
   rclpy.spin(camera_stream_publisher_node)
   # Destroy the node explicitly.
   camera_stream_publisher_node.destroy_node()
   # Shutdown the ROS client library for Python.
   rclpy.shutdown()
if __name__ == '__main__':
   main()
Create the camera_stream_subscriber.py file and populate it with the following code:
import rclpy
import cv2
class CameraStreamSub(Node):
   Create a CameraStreamSub class, which is a subclass of the Node class.
   def __init__(self):
       super().__init__('camera_stream_sub')
       # Create the subscriber. This subscriber will receive an Image
       # from the video_frames topic. The queue size is 10 messages.
       self.subscription = self.create_subscription(
           Image,
           'video_frame_data',
           self.listener_callback,
           10)
       self.subscription  # prevent unused variable warning
       self.running = True
   def listener_callback(self, data):
       Callback function to receive and display images.
       if self.running:
           # Convert ROS Image message to OpenCV image.
           current_frame = self.br.imgmsg_to_cv2(data)
           # Display image.
           cv2.imshow("camera_stream", current_frame)
           # Raise SystemExit exception to quit if ESC key is pressed.
           if cv2.waitKey(1) == 27:
               self.running = False
               cv2.destroyAllWindows()
               raise SystemExit
   Main function to initialize the node and start the camera stream subscriber.
   # Create the node.
   camera_stream_subscriber_node = CameraStreamSub()
   try:
       rclpy.spin(camera_stream_subscriber_node)
   # Exit if SystemExit exception is raised.
   except SystemExit:
       print("Camera stream output stopped")
   camera_stream_subscriber_node.destroy_node()
   rclpy.shutdown()
   main()
Add the entry points to setup.py inside console_scripts section:
'camera_stream_pub = camera_stream.camera_stream_publisher:main',
'camera_stream_sub = camera_stream.camera_stream_subscriber:main',
Since we already specified our dependencies during the package creation itself, we do not need to edit the package.xml file.
Build the package.
$ cd ~/ros2_ws
$ colcon build --packages-select camera_stream
Source the new package.
$ source install/setup.bash
Run the camera stream publisher node to start publishing the camera frames.
$ ros2 run camera_stream camera_stream_pub
In another terminal, run the camera stream subscriber node.
$ cd ~/ros2_ws
$ ros2 run camera_stream camera_stream_sub
The camera frames will be displayed in an OpenCV window.
You can press ESC on the active OpenCV window to exit.
    DAB over 1 year ago
    I assume you can continue to capture camera frames and store them in the background even when the display window is closed.
    DAB over 1 year ago
  • crisdeodates
    crisdeodates over 1 year ago in reply to DAB
    Yes. As long as the camera_stream_publisher node runs in the first terminal, it will continue to capture the camera images.
