Robotics
Robotics
Forum how do you connect things to the screen sorry im new and ima talking about just the screen and the little black and white tid bit
  • Subscribers 61 subscribers
  • Views 1077 views
tamagotchiwires
tamagotchiwires over 6 years ago
i took apart some stuff like calculators and i would like to know ho to put them to use
  • beacon_dave
    beacon_dave over 6 years ago +2 suggested
    I think you are referring to 'elastomeric' connectors (zebra stripes) used on LCD screens here. They just act as a high density ribbon cable between the conductive pads on the LCD panel and the conductive…
  • colporteur
    colporteur over 6 years ago +1
    Wow! The depth and breath of your questions can only be exceeded by the responses. Some of them you may not appreciate. If you can discover how to identify the components, you get one step closer to re…
  • beacon_dave
    0 beacon_dave over 6 years ago
    They just act as a high density ribbon cable between the conductive pads on the LCD panel and the conductive pads on the PCB containing the display drive electronics.
    dougw used an elastomeric connector in one of his micro:bit projects for PCB to PCB (rather than PCB to LCD) which may be of interest:
    BBC micro:bit - Big Idea Challenge
  • beacon_dave
