1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Documents 1 Meter of Pi - Winners Announcement
  • Author Author: e14phil
  • Date Created: 4 Feb 2021 2:38 PM Date Created
  • Last Updated Last Updated: 15 Feb 2021 5:31 PM
  • Views 9065 views
  • Likes 15 likes
  • Comments 35 comments
1 meter Pi challenge profile
1 Meter of Pi Design Challenge
About this Challenge | Dates | The Judges | The Kit | The Prizes | Technical Resources | Example Application | Terms & Conditions | The Challengers | The Winners
I am happy to announce today's Winners of the 1 Meter of Pi with Raspberry Pi Design Challenge!
After 20+ weeks of designing, researching, prototyping, coding, and testing, with 94 Blog posts and 46 Videos created, the 1 Meter of Pi Design Challenge has come to a close. Our challengers were tasked to use the Raspberry Pi to feed their spaceship crew as it blasts through the stars, with only 1M³ of growing space available.
The judges have rounded up their thoughts on the projects, and selected their favorites!
Kit used
The Kit Buy Kit*Buy Kit*The Specs
Raspberry Pi 4 2GB
Buy NowBuy Now
  • 1.5GHz 64-bit quad-core ARM Cortex-A72 CPU ( ARM v8, BCM2711B0)
  • 2GB RAM (LPDDR4)
  • On-board wireless LAN - dual-band 802.11 b/g/n/ac
  • On-board Bluetooth 5.0, low-energy (BLE)
  • 2x USB 3.0 ports, 2x USB 2.0 ports
  • Gigabit ethernet
  • 40-pin GPIO header
  • 2× micro-HDMI ports (up to 4Kp60 supported)
  • H.265 (4Kp60 decode)
  • H.264 (1080p60 decode, 1080p30 encode)
  • OpenGL ES, 3.0 graphics
  • DSI display port, CSI camera port
  • Combined 3.5mm analog audio and composite video jack
  • Micro-SD card slot
  • USB-C power
PIM487  Automation HAT Mini
Buy NowBuy Now
  • 0.96" colour LCD (160x80)
  • 1 x 24V @ 2A relay (NC and NO terminals)
  • 3 x 12-bit ADC @ 0-24V (ADS1015) (±2% accuracy)
  • 3 x 24V tolerant buffered inputs
  • 3 x 24V tolerant sinking outputs
  • 3.5mm screw terminals
  • Pimoroni breakout-compatible pin header
  • Mini HAT-format board
  • Fully-assembled (no soldering required)
  • Compatible with all 40-pin header Raspberry Pi models
  • Python library
  • Dimensions: 65x30x16.8mm
PIM486Enviro HAT for Raspberry Pi
Buy NowBuy Now
  • BME280 temperature, pressure, humidity sensor (datasheet)
  • LTR-559 light and proximity sensor (datasheet)
  • MEMS microphone (datasheet)
  • pHAT-format board
  • Fully-assembled
  • Python library
  • Dimensions: 65x30x8.5mm
PIM300PICO HAT Hacker
Buy NowBuy Now
  • BCM and descriptive pin labelling
  • Mounting holes (M2.5)
  • 0.8mm thick PCB
Prizes
PrizePrize Category
1meter pi grand prize
Grand Prizes*
  • Macbook Air
  • Pimoroni Picade
  • $500 Carbon Offset
1meter pi runner upRunner up*
  • iPad 10
  • Pimoroni Picade
  • $250 Carbon Offset
1meter pi Finisher
Finisher Prize
For anyone who completes 10 Blogs and a project with the featured product.
  • Solar USB Charger Battery Bank
  • Reusable Metal Straw and Cutlery Set
*Or local equivalent
Winners of the 1 Meter of Pi Design Challenge
Grand Prize
feiticeir0 – Space Vegetables
This project integrated Twitter, timelapses, and the Raspberry Pi camera to create a very effective hydroponic setup, making this garden up as one of the most fruitful. Also, I am a sucker for a good logo image. Check out the Twitter feed here: https://twitter.com/VegetablesSpace
So congratulations to feiticeir0 and his Space Vegetables!
Read Feiticeir0's Blogs here
1 Meter of Pi
Runner Up
milosrasic98  – Robot Assisted Garden AKA R.A.G
This was an amazing multidisciplinary project for one person to create, featuring a Nanny robot arm to tend to the plants within the enclosure, with 3D printed parts, Interchangeable tooling, a watering robot, all controlled elegantly within on GUI, powered by Pi! Milos never got to grow any plants in his garden, but the amount of work he did in such a short amount of time has been mindblowing.
Milos also included many sketches and designs for features he will continue to work on, expanding the project as time goes by.
Read Milos's Blogs here
1 Meter of Pi
Finishers
These projects won't be winning the top spot prizes, but we loved their work so much that we wanted to publicize their amazing efforts.
amgalbu - Project Gr0G
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/amgalbu
This build had room for plants on all surfaces, was self contained, had a great enclosure, along with a high pressure spray system.
Great environmental monitoring was built in, with a local access panel and a BLE Interface for controlling the pumps. It also unfolds easily for servicing.
If I had one more slot for a winner, this certainly would have been it!
gam3t3ch - Valley Forge Project Paperiniki
Valley Forge: Project Paperinik  #1 (Welcome)
Wesleys fully working garden uses watering hoses, optimized grow LEDs for a very effective grow. Wes also used off the shelf conduit and individually 3D printed connectors and joints.
On top of the initial build, this project comes with hours of engaging video and a real close up look at the ins and outs of this project. One thing we really liked is that along with the relay systems Wesley also included fusing to manage any over current issues. Wesley used Tarrarium Pi as the dashboard for this Raspberry Pi Powered system. He fought through leaks and other bugs to produce a wonderful project which really did fruit!
ilvyanyatka – Mushrooms Paradise
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/ilvyanyatka
A paradise for mushrooms! Utilizing an automated light, humidifier, and a set of fans, with online reporting using ThingSpeak.
All built within a pre-made insulated enclosure (a repurposed refrigerator, so a nice addition of upcycling to the project!).
jduchniewicz – Envidrawer
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/jduchniewicz
An under bed grow solution, built to take advantage of wasted space under the bed. The drawer remains closed until required, and open itself using motors during the day time to maximize light usage. I did have concerns about … quite literally.. wetting the bed. But it also had good basic environmental monitoring. There was also novel use of distance sensors that are often used in 3D printers. Although I am not entirely sure the total volume is under 1m3, the drawer is shallow enough to be given benefit of the doubt with this space saving project.
kurama007 – 2Pi Microgravity Garden
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/kurama007
A smart and effective hydroponic setup with some really nice features! Satoshi worked to tackle Self Pollinating Plants, Bug catching (sarracenia), and a closed loop water system, as well as gifting their garden with AI computer vision using Tensor Flow. This project has already featured in another Design Challenge, but the natural improvement and continuation of it has earned it a position as a Finisher.
hugohu
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/raspberrypitechguy
Hugo has built a simple but effective garden with Timed lighting and Watering features. I do worry that the LEDs chosen will not give the best results when growing plants, and that it is ... fairly tall in relation to the challenge brief. But it does feature all the fundamentals for life, and uses the components provided, so well done!
rockcacti – The Space Salad System
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/rockcacti
Anthony set up an closure, lighting, monitoring, and was even successful enough to grow radishes and lettuce in his garden. He also detailed issues and fixes when working with two competing Raspberry Pi HATs.
Anthony's Lettuce!
skruglewicz - EAS
Edible Algae System - (Growing Spirulina in space)
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/skruglewicz
A fantastic and data-led project, this is the first of the challenge projects to grow Spirulina instead of leafy plants. I really think this is the future of foods!
This project might not be as visually rich as some of the others in the challenge, but the data and work speak for themselves!
stevotech - Modular water distribution system.
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/stevotech
Ian created a wonderful mechanism that pressurizes and atomizes the water source in the bottom of the container; this system then equally distributes water across the multiple levels of the grow enclosure.
A new a novel method of watering, which I found very exciting!
embeddedguy
https://www.element14.com/community/community/design-challenges/1-meter-of-pi/blog/authors/ujjwalrathod00700
Ujjval used MQTT and an ESP8266 to make their sensors wireless and created the grow enclosure with controlled RGB grow lights.
  • 1 meter of pi
  • 1 meter of pi - design challenge
  • hugohu
    hugohu over 5 years ago +7
    CONGRATS TO THE WINNERS! Excellent projects! (yay I'm the first one here) (Oh wait dan beat me ) This contest was super fun and challenging! (The lights, were, probably not the best choice, but it was…
  • feiticeir0
    feiticeir0 over 5 years ago +7
    Uau ! I was not expecting that ! There are a lot of awesome projects here, and I did had fun and learn a lot by reading them, and people really did had a lot of work ! I must say it has been a lot of fun…
    balearicdynamics over 5 years ago +6
    Congratulations to all!
  • skruglewicz
    skruglewicz over 5 years ago
    Hello everyone. Hope you all are safe.
    Has anyone received the Finisher prize yet?
    I was just wonderinge14phil
    Kind Regards
    SteveK
  • e14phil
    e14phil over 5 years ago in reply to gam3t3ch
    It is a very cool project. I'm sorry I missed you in my wrap up. The final video has this weird relaxing personal charm that feels like I am just stood beside you as you are showing off your work. Its very cool. Very long but I felt engaged throughout!
  • gam3t3ch
    gam3t3ch over 5 years ago in reply to e14phil
    Yay! There I am.  Thanks e14phil for the add and kind words!
  • e14phil
    Just added from my written round up was the wonderful project from gam3t3ch Although he was included in judging, I had missed him as part of my Finished challenger wrap up.
    Please check out Wesleys work here:
    The accompanying video is an impressive 1 Hour 50 min long and it really feels like you are a guest in his workshop getting a private tour! I highly recommend watching it.
    • Vote Up +6 Vote Down
  • amgalbu
    amgalbu over 5 years ago
    Congratulations to all the challengers and thanks to PHutchinson for your appreciation!
  • kmikemoo
    kmikemoo over 5 years ago
    Awesome projects.  Congratulations to the winners and finishers.  Always impressive to see practical science at work.
    • Vote Up +5 Vote Down
    dougw over 5 years ago
    Congratulations. This was a tough topic - trying to create a full bio system and get plants to grow in the timespan of a project. Great work everyone.
  • stevotech
    stevotech over 5 years ago in reply to milosrasic98
    Thank you, Bruno and Milos. Great to see a lot of similar thinking in different parts of the world.
  • stevotech
    stevotech over 5 years ago in reply to feiticeir0
  • skruglewicz
    Congratulations feiticeir0 – Space Vegetables for taking  the grand prize. Great job. I enjoyed your daily reports. You deserve it.
    And milosrasic98  – Robot Assisted Garden AKA R.A.G., Congratulations  for taking the runner up place. great job also.
    To the Finishers, all wonderful and interesting projects. Congratulations to all as well. I will continue to follow you all and learn from your projects. Let's stay connected, Thank you in advance.
    Thanks to all the Judges for your time in evaluating all the blogs. You had a tremendous amount of content to evaluate.
    Thank you e14phil image for creating this blog and your comments on my design challenge blogs.. It is very helpful having all this information in one place. Thanks again for putting this design challenge together. I'm Looking forward to the next one.
    Steve K
