Blog Completed Project!
  • Author Author: roborob1266
  • Date Created: 31 Aug 2018 2:36 AM Date Created
  • Views 5414 views
  • Likes 17 likes
  • Comments 15 comments
  • adxl335eb
  • ra8875
  • hc-sr04
  • autism assistant
  • adafruit vs1053 mp3 player
  • design for a cause - design challenge
  • uno
  • mkr1000
  • adafruit ra8875
Completed Project!
roborob1266
roborob1266
31 Aug 2018
Hello all
I completed my project! Here are two photos of the devices used in this project.
1. MKR1000 (Arduino Board included in KIT
2. ADXL335EB (Tilt Sensor - included in KIT)
3. HC-SR04 (Ultrasonic Sensor - included in KIT)
4. RA8875 (Video Module - Adafruit Item 1590)
5. 5" Touch Screen display  (Adafruit Item 1596)
6. MP3 Player Music Shield (Adafruit Item 1788)
7. Arduino UNO
8. Jumper Wires (included in KIT)
9. USB cables for both the UNO and MKR1000 (USB cable included for MKR1000 in KIT)
Also, if anyone knows where to submit this for the Competition, please let me know so I can make sure it is submitted on time!
Thanks!
As a side note, the SD Proto Shield never worked out of the box. I tried touching the solder points but it didn't help, I researched about it on different forums and found out that there were a batch of these that were defective and needed to be replaced.
That is why I purchased and used the VS1053 MP3 Player with SD shield attached and it worked just fine!
Video of my project!
    shabaz over 8 years ago +6
    Hi Rob, Congrats! It's a great project.. nice to see it finally in action, your perseverance paid off! I'm working on something slightly similar as a side project, but it's dragging for me : )
  • aspork42
    aspork42 over 8 years ago +5
    Great job! I like what you have done! I think you still have some time left in the official contest so if there are other things you want to work out you might be able to. It would be cool to see icons…
  • 14rhb
    14rhb over 8 years ago +5
    Hi Rob, Very impressive work, well done on completing it Rod
  • roborob1266
    roborob1266 over 8 years ago in reply to three-phase
    Thank you Donald for the comment and encouragement!
    There were times I wanted to quit because I’m not a programmer or an electronics engineer so I was having a hard time but like you said persevered!
  • three-phase
    three-phase over 8 years ago
    Great project, well done for persevering and completing it.
    Kind regards.
    • Vote Up +5 Vote Down
  • roborob1266
    roborob1266 over 8 years ago in reply to aspork42
    Thanks James!
    I never heard anything about the deadline being extended from August 31st so that's why I completed it when I did.
    I will be working on the icons to show images instead of text.
    I think the code I was using for displaying an image used to much memory and kept causing the program to crash and restart.
    I want to get a case but I don't have anything to build it so I will have to see what is available to house all these items!
  • roborob1266
    roborob1266 over 8 years ago in reply to dixonselvan
    Thank you Dixon!
  • roborob1266
    roborob1266 over 8 years ago in reply to 14rhb
    Thank you Rod!
