Experimenting with Flyback Transformers
  • Experimenting with Flyback Transformers
Forum A 2 parter: does anyone know of a pwm controller that can work with 1.5v? and! Does this section of the element14 community remain active for like general flyback discussion?
Join Experimenting with Flyback Transformers to participate - click to join for free!
  • Replies 13 replies
  • Subscribers 42 subscribers
  • Views 2913 views
Anthocyanina
Anthocyanina over 2 years ago
Now that the time constraints have been removed, I want to keep working on my portable chaos toy. I started by taking apart the tiny transformer (the hot air station made this super easy) to rewind it with two symmetrical secondaries.
Now my goal is to power the converter with a rechargeable AAA battery, or if getting a low enough voltage pwm controller is not possible, a single 18650. So, does anyone know of a controller that can do that?
And well, my second question is if this section remains active in the community, or if this should be used only for the challenge and I should take my questions elsewhere?
Thank you!
  • javagoza
    javagoza over 2 years ago in reply to Anthocyanina +3
    If you are doing the winding yourself, you can still add an auxiliary winding to have a higher voltage, enough to power a common pwm regulator you can even use that auxiliary winding for regulator feedback…
  • cstanton
    cstanton over 2 years ago +2
    Anthocyanina said: And well, my second question is if this section remains active in the community, or if this should be used only for the challenge and I should take my questions elsewhere? We typically…
  • jc2048
    jc2048 over 2 years ago +2
    https://www.analog.com/en/products/lt1073.html
  • javagoza
    If you are doing the winding yourself, you can still add an auxiliary winding to have a higher voltage, enough to power a common pwm regulator you can even use that auxiliary winding for regulator feedback and not have to complicate measuring in the secondary.
  • Anthocyanina
    Anthocyanina over 2 years ago in reply to javagoza
    Thanks! I looked into this when i saw your response, it seems most controllers won't start with low vin, so now i'm looking into either designing a controller myself, or adding in a charge pump boost converter that kickstarts the whole thing
  • javagoza
    Maybe you can experiment with Blocking oscillators .
    Source: wikipedia
    Joule thief - Wikipedia
