Experimenting with Thermistors
  • Experimenting with Thermistors
Forum Is Ice water a constant temperature?
  • Replies 29 replies
  • Subscribers 8 subscribers
  • Views 9940 views
scottiebabe
scottiebabe over 4 years ago
Soft 404
  • Andrew J
    Andrew J over 4 years ago +3
    Graphs always make results look rubbish. Look at the slope on that! The accuracy is great though - serendipitously, these were the thermistors I picked for my project. My bet is no, it isn't. I don't…
  • scottiebabe
    scottiebabe over 4 years ago in reply to Andrew J +3
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago +2
    Ha, I also used ice water as an experiment when road-testing the Pico Datalogger with k-type thermocouples. It was far from constant, but all in plausible range. I did not think about stirring, but noticed…
  • scottiebabe
    0 scottiebabe over 4 years ago
    0 dougw over 4 years ago in reply to scottiebabe
    I always wondered why ice cubes in water don't grow bigger. Maybe its because thermal conductivity of water is higher than ice.
  • Andrew J
    0 Andrew J over 4 years ago in reply to scottiebabe
    Cool! Excuse the pun.  Even in the flask, that lasted longer than I thought it would.
  • scottiebabe
    0 scottiebabe over 4 years ago in reply to Andrew J
  • scottiebabe
    0 scottiebabe over 4 years ago in reply to scottiebabe
  • Andrew J
    If a pool noodle is what I think it is (it isn't a common expression in the UK!), foam-based floating support, then I'd think it would make an excellent insulator with all the air trapped in it.  That was a good experiment and I'm surprised to see that ambient warms to such a degree - 1.34W seems like a lot.  I know of some transistors that wouldn't hold up as well as that ice.
  • scottiebabe
  • Andrew J
    It's easy to forget that the air pockets make for a large surface area.  Your graph, for the 4 degree point looks fairly linear - was it like that all the way?  If not your thermal resistance is just a snapshot in time isn't it?  There is another option: most domestic fridges are set at around 4 degrees (perhaps 5) but it may not be clear or exact (mine has a circular knob that can move between "cool" and "eco" but without degree C markings.)  However, it should be constant as long as you don't keep opening the door.  If you can measure from within there - e.g. stuff your DMM, thermistor and flask in the fridge then ambient would be controlled - you could also use a second thermistor to measure how constant that fridge ambient was (how much hysteresis does it exhibit?): you could verify that thermal resistance!
    If nothing else, these are 'outside of the box' experiments with thermistors and good fun.
  • scottiebabe
    0 Jan Cumps over 4 years ago in reply to scottiebabe
    scottiebabe said:
    LM399
    Continuing on the tangent: I have a Keithley DMM6500 with an LT SL40057 reference. Rumours say it's an LM399 subset for (selected by) Keithley.
    image: blurry photo from my device
