Design Challenges
Design Challenges
Forum UPDATE Feedback on Experimenting with Waterproof Connectors PLUS a Poll on Test Equipment Prizes
  • Replies 19 replies
  • Subscribers 9 subscribers
  • Views 6328 views
  • waterproof connectors
rscasny
rscasny over 3 years ago
About three weeks ago, I posted a forum discussion called Seeking Your Feedback on Upcoming Experimenting Challenge -- Waterproofing Electronics. You gave me some great feedback (changing challenge prizes) and what to include in the challenge kit. This is a follow up to that discussion.
Summarizing the Experimenting with Waterproofing Challenge
The idea is pretty basic. We would give each participant a kit with waterproof connectors, a customized watertight enclosure (with holes drilled for the panel mount connectors) and a single board computer. Your challenge would be to put it all together. You would have to mount the SBC in the enclosure and wire it up. Then, perform experiments that test the waterproofing capabilities of the connectors and enclosure. Write about the results in some blogs.
Kit Version #3 --Current
Kit Version #2
From your previous feedback, I now want to pass by you the current version of the kit. Any feedback you have would be appreciated.
USB Type A
Drawing
Info
Datasheet
D-Sub
Drawing
Info
Datasheet
HDMI
Drawing
Info
Datasheet
Coaxial Cable Assembly
Drawing
Info
RJ45
Drawing
Info
Circular Connector
Info
Datasheet
Enclosure
Drawing
Info
SBC
Info
Poll: What is Your Preferred Test Equipment Prizes
Some of you had mentioned that you would like prizes other than consumer electronics. So, I collected some test equipment that I could consider as prizes. Vote on your most preferred one. If you have any other choices, please comment below.
Thanks for the feedback and comments.
  • rscasny
    rscasny over 3 years ago in reply to dougw
    I started looking for something that could be used and would be fairly inexpensive.
    dougw over 3 years ago in reply to rscasny
    I wasn't expecting a 1m tank to be supplied. Relaxed In case it came out that way...
  • rscasny
    Thanks for the reminder about both halves. I think we missed that last time we put connectors in the kit.
  • rscasny
    rscasny over 3 years ago in reply to Gough Lui
    Thanks for reminding me about both halves.
    This is an awesome kit. Some of the connectors are only rated IP67 when they are mated, so both halves are needed. We will also need a 1m immersion tank to test IP67.
  • Gough Lui
    Gough Lui over 3 years ago
    rscasny - Looks interesting and potentially straightforward to test. I look forward to applying (assuming I have the time). However, I just wanted to check that the connectors are not just "one-half" (i.e. the half that goes in the box) and that the mating versions of the waterproof connector are also supplied? Bonus points if both ends are terminated to some kind of cable to make it even easier.
    The reason I ask is that many waterproof connectors may not be "entirely" waterproof on their own. Sockets may resist water ingress, however, could be shorted out by the water if an approved, compatible, waterproof-version mating connector isn't plugged in correctly and (sometimes) screwed down tightly to ensure a good seal. Having just the sockets on the enclosure will not guarantee the safety of the connectors as their contacts may still be exposed to the liquid (which could be dirty, conductive, corrosive).
    - Gough
  • rscasny
    rscasny over 3 years ago in reply to wolfgangfriedrich
    Actually, the electronics are meant to be mounted in a watertight enclosure. So, what's being tested are IP67 waterproof connectors.
  • rsjawale24
    rsjawale24 over 3 years ago in reply to wolfgangfriedrich
    Potting compounds they are called. I always wanted to try them. You can find them on the bottom of electro mechanical relays and on some PCBs to protect them from moisture and corrosion
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago
    For an extra challenge, add a kit of clear epoxy resin to waterproof electronics that way. Might be tricky to ship those chemicals though.
    I always wanted to try that but never did.
