In the Air Design Challenge
  • In the Air Design Challenge
Blog In The Air [iot_healthy] #Post 5 : Its too Slow progress...
  • Author Author: ravi_butani
  • Date Created: 28 Nov 2014 3:56 AM Date Created
  • Views 1019 views
  • Comments 6 comments
  • sierra_wireless
  • element14
  • airvantage
  • iot_healthy
  • in_the_air
  • bbb
  • texas_instruments
ravi_butani
ravi_butani
28 Nov 2014
<< Previous
Table of contents
I am still finding Wind Shield wiper motor from near by scrap yard for automatic window opening and closing.
I have managed for exhaust fan from local scrapyard (230V 60Watt) and I will simply use relay switch for control this fan.
Still I am waiting for basic kits for this challenge, I have compiled and sent spreadsheet of components for my design to Element14.
Here is this spread sheet...
Line No.Order CodeQtyDescriptionMftr. & Part No.
118524943SOLAR PANEL, 0.8W, 4V, NO FRAMEMULTICOMP - MC-SP0.8-NF-GCS
223135522LI-PO BATTERY BOOSTERPACK, FOR LAUNCHPADELEMENT14 - BOOSTXL-BATTPACK
312967771TIP, D00663, 0.5MMDURATOOL - D00666
412967792TIP, D00661, D00662, 3MM, CHISELDURATOOL - D00668
5236475614.3INCH LCD DISPLAY CAPE, FOR BEAGLEBONEELEMENT14 - BB VIEW_43
624222281BEAGLEBONE BLACK REV C, CORTEX A8ELEMENT14 - BBONE-BLACK-4G
718914282SENSOR, HUMIDITY, 20-90%RH, +/-5%MULTICOMP - HCZ-D5-A
823569141ATMEGA32U4, YUN WIFI, EVALUATION BOARDARDUINO - A000008
This is all about this week... And I know that my the progress is too slow... and needs to be boosted.....
    mcb1 over 11 years ago +4
    Ravi Frustrating .. but at least it is forward. You may wish to detail some of the tasks that don't require the parts. ie the mechanism you will need to open the window, the distance, method the motor…
  • Problemchild
    Problemchild over 11 years ago in reply to fvan +3
    Good that he's showing pragmatism and willingness to try other methods when confronted by the dreaded "it will be here soon" beast !
  • tomaja
    tomaja over 11 years ago in reply to mcb1 +2
    I agree. Keep going Ravi! I am in a similar situation - my BBB arrived yesterday and I'm yet to receive LaunchPads and Inductor kits. But I also spent time on parts of my project that can be done without…
    Ravi
    You may wish to detail some of the tasks that don't require the parts.  ie the mechanism you will need to open the window, the distance, method the motor will connect with the opener, etc.
    You could also apply some thought as the the safe wiring needed to integrate the fan, relay and the low voltage wiring to switch it, while not constructing a potential hazard.
    You may also wish to start applying some thought into the final assembly, and what to put into the final summary blog for the judges.
    ie all those little details that need to be sorted later.
