Pi-Fest
  • Pi-Fest
Pi-Fest
Documents Pi-Fest Design Challenge
  • Author Author: e14phil
  • Date Created: 10 Mar 2022 2:15 PM Date Created
  • Last Updated Last Updated: 24 May 2022 3:12 PM
  • Views 16198 views
  • Likes 12 likes
  • Comments 30 comments
Make some noise with the Raspberry Pi Pico in the Pi-Fest music technology Design Challenge.
design challenge profile
About this Challenge | Dates | The Judges | The Kit | The Prizes | Example Application | Terms & Conditions | The Challengers
The Challenge
Make some noise with the Raspberry Pi Pico!
This new musical Design Challenge will put you and the Raspberry Pi Pico center stage.
50 successful applicants will get a Raspberry Pi Pico free of charge to use to build and blog their project. For the chance to win one of the prizes below, you must blog your build process and the final outcome of your Raspberry Pi Pico music or audio project. Use the Raspberry Pi Pico and any other Raspberry Pi products of your choice to create your music or audio project.
Successful projects will feature on our Pi-Fest livestream and challengers will be featured on our Pi-Fest tour poster.
Example applications could include:
• Synthesizer
• Podcasting Rig
• Live Music Production Machine
• AI Music Machine
• Sound level logging and Monitoring
The Sponsored Kit The Specs
Raspberry Pi Pico - 50 will be given away
Buy Now
Raspberry Pi Pico
  • Raspberry Pi designed RP2040 chipset
  • Dual core ARM Cortex M0+ processor at up to 133MHz with variable core frequency
  • 264kB SRAM & 2MB onboard flash memory
  • 26 Multifunction GPIO pins (23x digital only, 3x ADC capable)
  • 2x SPI, 2x I2C, 2x UART, 3x 12-bit ADC and 16x controllable PWM channels
The Prizes
Prize Prize Category
Winning Headliner
Live Music and Podcasting Bundle
Approximate Value $950 USD*
  • $500 of Ticketmaster Vouchers
  • Shure SM7B Professional Microphone and Stand
  • Go XLR professional USB Audio Interface
  • Headline Position on our Livestreamed Festival
  • Headline Position on your very own Pi-Fest Tour Poster
Supporting Act
Approximate Value $550 USD*
  • $250 of Ticketmaster Vouchers
  • Shure MV7 USB Microphone
  • Headline Position in your very own Pi-Fest Tour Poster
Finisher Prize**
To be a finisher you must complete 5 blogs and show us testing the resilience of their project.
Approximate Value $30 USD*
  • Multicomp Pro Multimeter
*Or local equivalent
**Grand Prize and Runner Up winners also earn the finisher prize.
The Judges
element14 Community Judges
element14 Community Team
The Dates
Project Phases Dates
Application Period 14th March 2022
Application Deadline 1st May 2022
Challengers Announced 8th May 2022
Build Period 8th May 2022 - 14th July 2022
Projects Due 14th July 2022
Winners Announced July 2022
Prizes Shipped July 2022
The Terms
Selected official applicants will be chosen to receive the "Kit" listed above; these successful applicants will be our sponsored challengers. The sponsored challengers must use the Raspberry Pi Pico within their project, and publish their final code and designs on the Community for others to use. Those not chosen as sponsored challengers may also join the competition and be eligible to win prizes, but they must base their projects around the Raspberry Pi Pico and adhere to all terms and conditions of the challenge.
Applicants must post their progress and final project as at least 5 blog posts before the closing date (see above), when projects are due. Challengers are strongly encouraged to post their blogs regularly during the contest period, rather than posting them all close to the finish of the competition.
Projects that use the Raspberry Pi Pico most creatively, along with posts that are media rich with photos, videos, and code samples will be viewed more favorably in the judging process.
Please read the full terms and conditions of the challenge, attached below.
Ready to join the challenge? Then apply here!
If you are not successful in becoming a sponsored challenger, but still want to enter, all you need to do is use the Raspberry Pi Pico as described above in your project and adhere to the same Terms and Conditions for a chance to be our winner! Non-sponsored challengers are eligible for the Finisher and Winner Prizes, as well.
  • design challenge
  • raspberry pi
  • pi-fest
  • skruglewicz
    skruglewicz over 4 years ago +2
    I heard about this challenge on LinkedIn, Surprising since I'm an active member of the Element14 community. I have participated in many design challenges and Roadtest here on Element14. I am a retired…
  • scottiebabe
    scottiebabe over 4 years ago +2
    If only I had musical talent LOL This sounds like yet another fun activity happening on E14. When the time comes I think I will tinker away at making pico wah effects pedal. I believe a wah pedal is…
  • feiticeir0
    feiticeir0 over 4 years ago in reply to mr_lindowsmac +2
    Usually they are announced on the page. They are late.
    Jan Cumps over 4 years ago in reply to scottiebabe
    You're dealing with these frequencies - if it's an electric guitar:
    source: google
    With highest frequency at 10 kHz, a 22 kHz sample would do?
    According to this blog (I have the Cry Baby that they show there), you should be able to move the filter between 350 Hz and 2.2 kHz.
  • scottiebabe
    scottiebabe over 4 years ago in reply to Jan Cumps
    I think so too! I am most concerned with the mechanics and calculating new FIR tap weights based on an ADC reading of pedal position. I am pretty sure I can run a 128 tap filter at 44 kHz, maybe more...
    Yes, a Wah should be doable. The parameters to control are limited: the resonance frequency.
  • scottiebabe
    I believe a wah pedal is just an adjustable BPF,
    I can run a little FIR filter on the second core of the RP2040
    Many projects to work on before this one Stuck out tongue
  • phoenixcomm
    phoenixcomm over 4 years ago
    Hmm,  I need a good FAA Morse Code gen. I think I can feed the "alpha" ie  Dallas is "SDAL" in Morse. "... -.. .- .-.."
  • feiticeir0
    This looks fun ! I'm not a sound expert, but a Raspberry PICO is very versatile and people come up with new applications for it all the time. Let's dance !
    Jan Cumps over 4 years ago in reply to skruglewicz
    It's announced on one of the colourful tiles at the top of the home page. It didn't appear in one of the community activity lists, or search (for me).
  • skruglewicz
    I heard about this challenge on LinkedIn, Surprising since I'm an active member of the Element14 community. I have participated in many design challenges and Roadtest here on Element14. I am a retired Software Engineer and Have been a Musician all my life. I now do Music as a hobby along with experimenting with IoT. I have 5  PI's that I augured from the mention activity here on Element14. I've been following the Pico activity since It came out, but never had the time to experiment with one. This might be the challenge, where I have the motivation.to give it a spin. I have many imany musical idea's to design and implement..
    Looking forward to the Challenge
    @skruglewicz
  • ralphjy
    ralphjy over 4 years ago
    It does sound like a fun challenge.  I haven't done anything with audio using the RP2040.  Trying a synthesizer or AI music machine would be interesting.  I'll have to see if I can come up with a project.
    dubbie over 4 years ago
    This looks fun. I do not have much Pi experience (I'm more of a cake person) but maybe this is the opportunity to learn some more and get some real experience and understanding. I'm not much for audio, music or sound either - they're not really needed for mobile robots, but you never know, if I put my thinking AND ideas hats on I might be able to come up with something.
    Dubbie
