Rocking Raspberry Pi
  • Rocking Raspberry Pi
Blog Road blocks to Karaoke
  • Author Author: bharatrai888
  • Date Created: 26 Apr 2014 4:36 PM Date Created
  • Views 2485 views
  • Comments 14 comments
  • rockingraspberrypi
  • karaoke
  • rocking_pi
bharatrai888
bharatrai888
26 Apr 2014
Hi Friends,
In previous post I write about the use of raspberry with wolfson pi. I talked about the usage of the wolfson.
If talking about the karaoke which is our main target the raspbian fails as I already said in my starting post. Whereas the RaspBMC provide lag free music and video playback which is our main motto. As we all use it as karaoke which means using raspberry pi as media device.
So according to my experience and point of view the RaspBMC is best solution for this.
So for this I first backup my Raspbian data and restored my RaspBMC image which used to backup earlier.
And again it was the awesome feeling while playing lag free media.
Again going through each setting of raspbmc I also found the karaoke option inside the RaspBMC settings option.
At this point I enabled the option but while playing .kar file it fails.
Looking for the solution on the internet I found to put the soundfont.sf2 file and a blank timidity in the timidity folder which is located in ~/.xbmc/userdata/
I do the same but still it fails to open midi files. Looking inside the error log I compared it with the XBMC windows version logs. I found that there is no line containing timidity in the RaspBMC error log.
Other than that the initial idea which I have planned is working.
I am still searching for the proper solution which may help in playing midi files in RaspBMC.
Otherwise I’ll come up with initial idea to use raspberry pi as fully controlled karaoke machine.
  • cstanton
    cstanton over 12 years ago
    Isn't RaspBMC based on Raspbian and so you can just use the package which ragnar.jensen made to replace the kernel/install modules ?
    e14 Contributor over 12 years ago in reply to bharatrai888
  • bharatrai888
    bharatrai888 over 12 years ago in reply to e14 Contributor
    No, I haven't use wolfson with the RaspBMC.
    I am just trying to make a simple karaoke. which is not going to use wolfson. image As there is no documentation to get the wolfson work with the RaspBMC.
    -- Bharteindu
    Are you saying that you have you been able to get the Wolfson  card to work with RaspBMC?
    Ragnar
