Sixth Sense Design Challenge
  • Sixth Sense Design Challenge
Blog 13A capable motor driver - Automatic Weeding Robot #5
  • Author Author: weiwei2
  • Date Created: 1 Mar 2019 6:21 AM Date Created
  • Views 1791 views
  • Likes 9 likes
  • Comments 6 comments
weiwei2
weiwei2
1 Mar 2019
wow, time flies, i realize i haven't posted anything for 1 months plus. This post is a relatively short post
i was out for oversea trip for 2 weeks, also another 1 week for Chinese New Year holidays, nonetheless over the last one month, i have look at trying to build my motor driver circuit with MOSFET
i got some IPT60R028G7 infineon COOLMOS high current MOSFET, which is capable of 75A continuous drain current and an optocoupler TLP521-4
i then research on some home DIY PCB making methods that i haven't tried - using Vinegear and hydrogen peroxide like in https://electronics.stackexchange.com/questions/185824/hydrogen-peroxide-for-pcb-etching
seriously it seems i haven't design a proper PCB for quite some time, but is hesistant to use ferric chloride
However, later on i discover a 13A capable driver board so i eventually just got myself 2 driver boards (since i have 2 motors)
It has grove compatible control interface hence i am adding a grove shield to my setup. Now, i haven't crosschecked if the STM32F411RET6 will be
compatible with a grove shield. If it is not, i can always do a dumb action, let the MCU talk to an arduino uno with grove shield
So i have decided to still do without PCB first
here are the motor drive test line up
Next step
-test the 13A module today and write an update post tomorrow
Next next step
- come out with system model with Altair Embeb that can be simulated
  • 14rhb
    14rhb over 7 years ago +4
    I ran into similar issues getting my R2B4 to move along but am opting for a drive belt reduction to gain torque. I am glad to see you are overcoming your problem - I'm looking forward to watching it in…
  • weiwei2
    weiwei2 over 7 years ago in reply to 14rhb +4
    my initial testing with just bench power supply looks promising. updated to blog #6 Motor driver testing with bench top power supply - Automatic Weeding Robot #6 i find the voltage level, other than current…
  • BigG
    BigG over 7 years ago +4
    If you want a relatively quick and simple way to design and get custom prototype pcb's made then my suggestion is that you should look at using this online tool - it is quick to grasp the concepts and…
  • 14rhb
    I ran into similar issues getting my R2B4 to move along but am opting for a drive belt reduction to gain torque. I am glad to see you are overcoming your problem - I'm looking forward to watching it in action (no chasing those cute Guinea Pigs around the garden)
    Rod
