element14 presents
element14 presents
e14 presents blogs Arduino, Raspberry Pi, or ??? I'm Hacking Philips Hue Lights and I need your help!
  • Author Author: TechnoChic
  • Date Created: 1 Mar 2023 5:03 PM Date Created
  • Views 3801 views
  • Likes 10 likes
  • Comments 19 comments
  • Philips Hue
  • led
  • raspberry pi
  • led lighting
TechnoChic
TechnoChic
1 Mar 2023
Hi! It's Natasha.
I'm working on my next project for Element14 Presents which involves hacking the Philips Hue Lighting System. I need your help to determine which path I should take - please watch the video for the details of the project:
I will need to spend a lot of time learning to work with the Philips Hue API (and there's even a new one that just came out!) So, I want to make a well-informed decision:
  1. Should I use Arduino, Raspberry Pi, or another system?
  2. I will need 5 sensors (one under each cabinet) to detect my presence within a few feet of the sensor. What sensor system is best? Will it connect easily to the microcontroller system?
  3. What other ideas do you have for controlling the Hue Lights?
Please let me know your thoughts in the comments below. Thanks in advance for your help!
    dougw over 3 years ago +1
    If you are more comfortable with Python, go with the Pi Pico W, if you prefer C, go with the MKR WiFi, although they can both be used with either language. Availability may also dictate which one to use…
  • Fred27
    Fred27 over 3 years ago
    I did a bit of hacking with Philips Hue, but it was quite a few years ago. I took an entirely diffeent approach and hacked the hardware so that I could build custom lights that were controllable from the Hue ecosystem. Maybe not too relevant to your project but here's some info if you're interested:
    https://0xfred.wordpress.com/category/electronics/philips-hue/
    Getting back to your question, I'd definitely be tempted to go with a Pico for any new projects. It's cheap, it's available, and the development environment  seems to work well. It used to be a little clunky to set up but there are some good tips here on E14 and apparently they have improved the setup if you're on Windows. In theory it would be possible to go directly to Hue via Zigbee, but that seems quite locked down. Your idea of Wifi and Hue API seems like a good pragmatic approach.
  • TechnoChic
    TechnoChic over 3 years ago in reply to shabaz
    Ah that's good to know! But if I was making toast I suppose I'd be close to that area anyway and want it illuminated. I'm hoping to make a smooth transition so triggering a section will illuminate in a slow fade and go back to default slowly too, so as not to make any jarring light flashes!
  • TechnoChic
    TechnoChic over 3 years ago in reply to fmilburn
    Ooooh I'm intrigued by that "Radar" sensor. Thanks for this!
  • TechnoChic
    Interesting! I hadn't heard of that type of sensor before. I'd want it to be able to be triggered by motion within a 0 in to 2-foot range.
  • TechnoChic
    TechnoChic over 3 years ago in reply to dougw
    Thanks! What IR sensor specifically do you like?
