element14's The Ben Heck Show
Forum Need Advice - DIY Sea Turtle Nest Temperature Logger
  • Replies 19 replies
  • Subscribers 33 subscribers
  • Views 1942 views
Hey y'all,
I'm hoping the title caught your attention. I'm a graduate student looking to assemble temperature data loggers, which will be buried in the sand for approximately 2 months. They run about $40 from established companies, but I would not have the funding to buy enough. I figured the DIY approach could produce the same results.
Standalone Temperature/Voltage Logger « insideGadgets
This is essentially what I'm looking to produce. Although with this kit I would need to improve the thermistor to one that has an error of 0.5 degrees Celsius.
The data logger would need to be weather-proofed, as it's going to be coated in sand, with the possibility of water. However, I do need to access the data later.
Any and all advice would be greatly appreciated.
  • vsluiter
    vsluiter over 12 years ago in reply to michaelkellett
    Yes, you can look at this Ramtron part http://nl.farnell.com/ramtron/fm25640b-g/fram-64k-spi-8soic/dp/2077754 or at Cypress's parts : http://www.cypress.com/?mpn=FM25V01-G . I see now that they are waaay more expensive though , and thus mot particularly suited to your project.
    There's some background info here too: http://www.ti.com/lsds/ti/microcontroller/16-bit_msp430/fram/overview.page?DCMP=FRAM&HQS=FRAM. The low power properties are especially useful if (re-)writing large chunks of data, which you are not going to do. TI makes the MSP430 (low power micro) also with internal FRAM, but I don't know if it would suffice for your purpose. This one has 16kByte storage (used for both data and program): http://nl.farnell.com/texas-instruments/msp430fr5728irget/ic-mcu-16bit-msp430-24vqfn/dp/2072183 . The interesting thing is that you have a low power microocontroller with nonvolatile storage and an RTC in one package. Still more expensive than Michaels options, but you'll have to place only one part....
  • Problemchild
    Problemchild over 12 years ago
    Dallas did some sensors which were for food shipment temperature checking etc.
    The battery  lifetime is a function of the sample rate so you cut the cloth to what can be achieved
    Dallas thermocron DS1921G http://www.maximintegrated.com/en/products/comms/ibutton/DS1921G.html/tb_tab0
    Should be what you want and it's environmentally sealed as well
    michaelkellett over 12 years ago in reply to Problemchild
    The iButton thingy doesn't really meet the OP's spec (not good enough resolution or accuracy) and is only just good enough re. number of measurements.
    We haven't heard form Dan for a while so perhaps he's given up.
  • Problemchild
    Problemchild over 12 years ago in reply to Problemchild
    Mike I agree that the particular ibutton  type is marginal to his alluded to spec's the question is does he really need that accuracy or is this what he assumes he needs also any build been suggested would need to be calibrated and proved to in the original spec even if the original components promise this.
    Further more you could pick a different model (more accurate)if they exist and you could calculate whatever offsets these units have via a process of calibration so you can adjust results according to this process. Also 1 deg c is over the full -40-85c so over the normal "Turtle" range this is likely to be much less.
    Any way as you can see they are close enough to initial spec to buy a few and evaluate !!
    The other issue was the price - (I remembered there was a big problem - it just eluded me for  a while today)
    http://www.embeddeddatasystems.com/DS1922L-F5--Thermochron-iButton-40C-thru-85C_p_98.html
    10 - 24 off, $46 which was where the OP came in - total budget about $500.
    I don't quite know waht happened to iButtons - seemed a nice idea but it's fairly obvious that little or no development has been done on them for years. I designed a product with a built in reader once (about 12 years ago).
  • Problemchild
    Problemchild over 12 years ago in reply to michaelkellett
    The iButtons are used a lot in retail particularly pubs where they need to identify the bar person so they can run multiple tallys.
    Even in the UK  the price is more like $20 should be able to get 2/3 that some where else
    Temperature Logger Ibutton Ds1921g f5 | Rapid Online
  • Problemchild
    That place sounds expensive ...unusual that a US specialist is like twice the price of a UK general stockist!
    You have to compare apples with apples image
    http://www.embeddeddatasystems.com/DS1921G-F5--Thermochron-iButton-40C-thru-85C_p_5.html?gclid=CIffuuqI974CFa3LtAodRm0AKA
    $22 each = £12.94 (@ 1.7:1 exchange rate)
  • Problemchild
    Yep that's more like it.. I think this thread has gone stale ..it would be nice to get some input from Mr Turtle Man         !!
