      • Japan
      • Vietnam
DC to Daylight
  • DC to Daylight
DC to Daylight
Documents Driving LEDs to Create a Flux Capacitor -- DC to Daylight 08
Join DC to Daylight to participate - click to join for free!
  • Date Created: 10 Mar 2022 3:57 PM Date Created
  • Last Updated Last Updated: 16 Mar 2022 8:24 AM
  • Views 35859 views
  • Comments 6 comments
In this episode we make a PWM LED driver using transistors and an Arduino Nano, which provide dimming and sequencing functionality for a Flux Capacitor. While not an exact replica, it does make a good demonstration of pulse width modulation and how to drive LEDs with a current sink/source
Supplemental Content:
  • Resources
element14 presents
element14 presents  | About Derek  |  DC to Daylight
  • LED driver
  • arduino nano
  • back to the future
  • derek
  • arduino pwm
  • current source
  • flux capacitor
  • pulse width modulation
  • pwm led
  • light emitting diode driver
  • current sink
  • bttf
  • Derek (DCtoDaylight)
    Derek (DCtoDaylight) over 3 years ago
    Hello all! If you have suggestions on how to improve this project, especially related to software let me know here. One of the things I'd like to do is to "power up" three LEDs at the same time so the pulsing looks more natural... meaning three of the LEDs are actively ramping through the PWM values out of phase. I think this would require three nested loops and maybe a state machine. Ideas?
    Jan Cumps over 3 years ago in reply to Derek (DCtoDaylight)
    One loop should do:
    Let's say as example that when LED A is 0, then B is 85, 3 = 130 (each 1/3 offset of each other).
    #define A_OFFSET 0
    #define B_OFFSET 85
    #define C_OFFSET 130
    uint8_t counter = 0;
    // helper method
    void setLed(uint8_t pin, uint8_t value, uint8_t offset {
      uint8_t intensity = ((uint32_t)(value + offset)) > 255 ? 255 : (value + offset);
      analogWrite(pin, intensity);
    // where you want to make them glow:
    for (counter = 0; counter <= 255; counter++) {
      setLed(A, counter, A_OFFSET);
      setLed(B, counter, B_OFFSET);
      setLed(C, counter, C_OFFSET);
    One loop should do:
    #define A_OFFSET 0
    #define B_OFFSET 85
    // helper method
    Jan Cumps over 3 years ago in reply to Jan Cumps
    ... but that will make led 2 and 3 flip directly to their offset value, and that's not what you want he?
    Changing the helper function should fix that. Thinking ...
    #define A_OFFSET 0
    #define B_OFFSET 85
    #define MAX_OFFSET C_OFFSET
    // helper method
    void setLed(uint8_t pin, uint32_t value, uint8_t offset) {
    uint8_t intensity = 0;
    if (value > offset) {
    intensity = (value - offset) > 255 ? 255 : (value - offset);
    for (uint32_t counter = 0; counter <= 255 + MAX_OFFSET; counter++) {
