DC to Daylight
  • DC to Daylight
DC to Daylight
Documents How Electromechanical Relays Work -- DC to Daylight 09
Join DC to Daylight to participate - click to join for free!
  • Date Created: 31 Mar 2022 12:43 PM Date Created
  • Last Updated Last Updated: 6 Apr 2022 7:24 AM
  • Views 91743 views
In this theory-based episode, we take a quick look at the evolution of the relay, how it changed telegraphy, and how to actuate a relay safely from a low-current source like a microcontroller. The method I typically use to select the proper base resistor for a given BJT transistor is presented, as well as why you always see a freewheel protection diode across the relay coil; the resulting waveform with, and without protection diode are viewed on the oscilloscope.
element14 presents
element14 presents  | About Derek  |  DC to Daylight
  • transistor driver
  • drive relay
  • derek
  • electromechanical relay
  • electromagnet
  • morse relay
  • relay
    dougw over 4 years ago
    Good explanation - I like the history of the relay lesson. I tend to use FETs instead of BJTs. You mentions a couple of terms for the diode - there seem to be lots of terms that people might use: freewheeling diodes, kickback diodes, clamp diodes, commutating diodes, suppression diodes, or snubber diodes
