DC to Daylight
  • DC to Daylight
DC to Daylight
Documents Getting Started with Bluetooth LE Audio Using the Nordic NRF5340 -- DC to Daylight 19
Join DC to Daylight to participate - click to join for free!
  • Date Created: 1 Nov 2022 3:15 PM Date Created
  • Last Updated Last Updated: 9 Nov 2022 8:24 AM
  • Views 200610 views
  • Comments 9 comments
In this episode I'm going to show you how to get started with the Nordic Semiconductor nRF5340 Audio Development Kit. Utilizing the LC3 CODEC the nRF5340 Audio DK can stream high quality audio between a gateway device and a headset device, depending on configuration. Streaming is done over bluetooth low energy, or BLE, and digital audio can be broadcast to multiple headsets or stream to a pair of headsets offering TWS or True Wireless Stereo. I'll take you through the basics of the hardware, the software you'll need to download in order to compile and run the demo, as well as how to program and flash the device.
Watch the Video:
Supplemental Content:
  • Audio Streaming Quiz
  • Learn the Basics and Implementations of Bluetooth LE Audio and its Applications
Bill of Materials
NRF5340-DK NORDIC SEMICONDUCTOR 4
Buy Now
element14 presents
element14 presents  | About Derek  |  DC to Daylight
  • ble
  • nordic
  • LC3
  • bluetooth low energy
  • Audio development kit
  • Cpy_2011
    Cpy_2011 7 months ago
    Hi Derek,I have one nRF54l15 DK, I try to let it connect my headphones but no voice, I’m sure it connected by BLE, do you know how to fix it?
    e14 Contributor over 3 years ago in reply to Sanmeet
    Hi Sanmeet. I started to look into this when I was putting the video together, but it was a little too deep to get into at the time... it looks like there is a walkie-talkie demo. See in the nordic forum: https://devzone.nordicsemi.com/f/nordic-q-a/96907/nrf5340-audio-dk-walkie_talkie-no-bidirectional
    I haven't tried, but I might later this week if I have time. Also, I think you may have to solder some jumpers to get the digital mic to work as an input - don't quote me, but I think I saw that in the datasheet.
  • Sanmeet
    Sanmeet over 3 years ago
    HI Derek, what changes do I need to make if I want a bidirectional audio transmission like an intercom using two boards? TIA!
    DAB over 4 years ago in reply to e14 Contributor
    I do like thunderstorms.
    I also take lightning photos.
    You can also use some filters to keep a lot of the man made noises out.
    e14 Contributor over 4 years ago in reply to DAB
    You certainly could, though I wonder about the external noise you would also pick up from unwanted sources... like automobiles, or other man-made things. It may be more enjoyable to use it as a traditional bluetooth speaker and connect the source to a computer or phone.  Personally I use one of those "voice recognition devices" and request it to play thunderstorm sounds.
    It would have the advantage that you could control it however you want though, which makes the application appealing.
    Interesting board.
    I was wondering if you could use the pair to relay bird songs from outside the house to inside.
    When we close up the house for using the air conditioner, we also lock out the songs of the many birds around the house.
    beacon_dave over 4 years ago
    It would be interesting to see an end-to-end latency test from the line input of one dev kit to the headphones output of another dev kit in broadcast mode.
    Does the demo application allow for a single dev kit to receive both left and right channels from a gateway or would this require three dev kits configured as gateway, left & right?
    e14 Contributor over 4 years ago in reply to FinnvF
    Hi Finn.
    Thank you for the input regarding the recover flag. Afterwards, I dug into the forums a bit more and the nRF5340 documentation as well, and it became more clear to me. Initially I didn't realize that *recover* equated to reset registers including app protect. Thank you for further explaining!
    -Derek
  • FinnvF
    FinnvF over 4 years ago
    somewhere around 11:40 or so Derek refers to using  -- recover and not exactly knowing what it is about. You use that basically completely reset the device including special registers used for APPROTECT.
