      • Japan
      • Vietnam
DC to Daylight
  • DC to Daylight
DC to Daylight
Documents 5 Real-World Capacitor Applications & Micro Teardowns -- DC to Daylight 27
Join DC to Daylight to participate - click to join for free!
  • Date Created: 16 May 2023 3:19 PM Date Created
  • Last Updated Last Updated: 17 May 2023 7:24 AM
  • Views 74936 views
In this episode we're going to go over 5 different capacitor applications: 1. Linear power supplies, 2. AC-Coupling / DC-blocking, 3. Bypass Capacitors, 4. Condenser Microphone Capsule and 5. Decoupling Capacitors. This time I'll spare you the math, show you an overview of each schematic, then we'll do a micro teardown and take a couple of measurements at the same time. If you like to take things apart, then this episode is for you!
Watch the Video:
Bonus Content:
  • Schematic
Bill of Material:
Product Name Manufacturer Quantity
Multilayer Ceramic Capacitor, 47000 pF, 50 V, ± 10%, PC Pin, X7R, 5.08 mm Multicomp Pro 1 Buy Now
Multilayer Ceramic Capacitor, 0.1 µF, 50 V, ± 10%, Radial Leaded, X7R, 2.54 mm Vishay 1 Buy Now
RES, 6K8, 0.25W, AXIAL, METAL FILM ROHS COMPLIANT: YES Multicomp Pro 1 Buy Now
Through Hole Resistor, 220 ohm, MCF Series, 250 mW, ± 5%, Axial Leaded, 250 V Multicomp Pro 1 Buy Now
Logic IC, Inverter, Hex, 1 Inputs, 14 Pins, SOIC, 74AC14 Onsemi 1 Buy Now
RF / Coaxial Connector, BNC Coaxial, Straight Bulkhead Jack, Solder, 50 ohm AMPHENOL RF 1 Buy Now
LM386MMX-1/NOPB Audio Power Amplifier Texas Instruments 1 Buy Now
element14 presents
element14 presents  | About Derek  |  DC to Daylight
  • capacitor
  • capacitor applications
  • condenser mic
  • charge
  • dc blocking
  • ac coupling
  • decoupling capacitor
  • filter
  • Derek (DCtoDaylight)
    Derek (DCtoDaylight) over 2 years ago in reply to DAB
    Thanks. There are sooo many different applications - I couldn't fit them all in. I wanted to add peak detectors, op amp circuits, RF stuff, filters, charge pumps... saved for a rainy day.
    DAB over 2 years ago
    Very good episode.
    It has been quite a while since I looked at these types of circuits, so you brought back a lot of memories.
