The Electronics Inside
  • The Electronics Inside
Documents Apple Macintosh SE/30 Teardown -- The Electronics Inside 50
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 4 Jan 2022 4:19 PM Date Created
  • Last Updated Last Updated: 26 Jan 2022 8:24 AM
  • Views 5180 views
Adding to the Apple history teardowns, let's jump to the 1980s. We have already looked at a "Luggable" from the 1980s, so what did Apple have to offer?
Supplemental Content:
  • iMac G3: The Electronics Inside 02: iMac G3 Teardown
  • iMac G4: The EIectronics Inside 14: Apple iMac G4 Teardown
  • Apple Newton (Message Pad): The EIectronics Inside 19: Apple Newton Teardown
  • iPod: The EIectronics Inside 30: iPod Vs Zune Teardown
element14 presents
element14 Presents  |  About David|  Project Videos  |  The Electronics Inside
  • All in one
  • vintage computing
  • apple
  • macintosh
    beacon_dave over 4 years ago in reply to a531016
    Also perhaps worth noting is there are no key slots next to the contacts for a general user to align a mating connector. The signals are the same either side and contacts are quite widely spaced, so potentially designed for some form of diagnostic clip, or test jig ?
    Good question. The remaining pins appear to be power rails along with three connections to the first 3 IO pins on port A of a 65C22 VIA.
    VIA1 and VIA2 (65C22) schematic
    https://museo.freaknet.org/gallery/apple/stuff/mac/andreas.kann/SE30_P4.GIF
    So diagnostics connector perhaps.
  • a531016
    a531016 over 4 years ago in reply to beacon_dave
    Well done for digging that up! You clearly did much better than me with the research. Although I'm still a little lost ast to what it may be used for? Does this suggest that the logic board was somehow used in a different configuation a little like a blade? Or maybe this port was used during diagnostics in manufacture?
    The unidentified J14 edge connector appears to carry differential serial lines.
    Shown here on the Power Connector, Pullups & Pulldowns schematic:
    https://museo.freaknet.org/gallery/apple/stuff/mac/andreas.kann/SE30_P8.GIF
    and again on the Serial Interface and Sound Interface schematic:
    https://museo.freaknet.org/gallery/apple/stuff/mac/andreas.kann/SE30_P7.GIF
    Looks to go back to a 8530 serial communication controller and is shared with the external modem port.
