      • Japan
      • Vietnam
The Learning Circuit
  • The Learning Circuit
Documents Replacing MLCCs with Polymer Capacitors -- The Learning Circuit 42
  • Date Created: 25 Dec 2018 3:15 AM Date Created
  • Last Updated Last Updated: 27 Feb 2019 8:24 AM
  • Views 3417 views
  • Likes 8 likes
  • Comments 7 comments
The Learning Circuit | element14 presents |  Project Videos
Polymer capacitors offer low ESR and high capacitance in a small package. See what happens when a tantalum polymer replaces an MLCC in a DC-to-DC converter. Or, check the result of replacing a traditional electrolytic capacitor with an aluminum polymer. For fun, James shows measurements on a modern switching power supply and goes back to a classic 8-bit favorite, the Commodore 64.
Take the Polymer Capacitor Quiz
Learn more about Passive Components
Join the Experimenting with Polymer Capacitor Competition
Supplemental  Content:
  • The Learning Circuit 40: Learning About Polymer Capacitors
  • Measurements from replacing MLCCs with Polymer capacitors (TLC #42 Extra)
  • Why does this C64 electrolytic capacitor have AC applied to it?
Bill of Material:
Part
Test Tools
WXMT MS (Micro Soldering Tweezers)
Weller1Buy NowBuy Now
RTM3004 Oscilloscope
Rohde and Schwarz1Buy NowBuy Now
Power Rail Probe - RT-ZPR20Rohde and Schwarz1Buy NowBuy Now
Handheld DMM (72-7780)Tenma1Buy NowBuy Now
Adjustable Electronics LoadBK1Buy NowBuy Now
PCB HolderPanavise1Buy NowBuy Now
Module
TPS62097EVM Evaluation ModuleTexas Instruments1Buy NowBuy Now
Soldering Supplies
De-Soldering Wick 484-2 (0.05")American Beauty1Buy NowBuy Now
SnPb Solder 0.02" Rosen Core (SPC22130)Duratool1Buy NowBuy Now
SMD291AX Solder Paste, No Clean, SyringeChip Quik1Buy NowBuy Now
SMD291 Solder Flux, No Clean, SyringeChip Quik1Buy NowBuy Now
Capacitors
Original 22uF 0805 Ceramic Capacitors (C2012X7S1A226M125AC)TDK1Buy NowBuy Now
Tantalum Polymer 22uF (T529P226M010AAE200)KEMET1Buy NowBuy Now
470uF 25V Aluminum Polymer (A750MS477M1EAAE015)KEMET2Buy NowBuy Now
2200uF 16V Aluminum Polymer  (RNL1C222MDS1)Nichicon1Buy NowBuy Now
  • polymers
  • polymer capacitor
  • replacing mlccs
  • polymer electrolytic capacitor
  • mlcc alternatives
  • e14presents_baldengineer
  • aluminum polymer capacitor
  • tantalum polymer capacitor
    DAB over 6 years ago +2
    Good video. As you point out, testing is key to understanding how different types of components affect specific circuits. There is much more to engineering than just copying circuit diagrams and putting…
  • Gough Lui
    Gough Lui over 6 years ago +2
    I enjoyed the video along with the (at times) suspenseful moments looking for improvements. I know in the past, I've tended to do "shotgun" style repairs where I will replace capacitors wholesale, mostly…
  • Gough Lui
    Gough Lui over 6 years ago in reply to baldengineer +2
    Thanks for the reply - I can definitely understand especially if you don't have an ESR meter to hand as it isn't necessarily easy to measure or interpret. In fact, I invested in one pretty early on as…
  • Gough Lui
    I enjoyed the video along with the (at times) suspenseful moments looking for improvements. I know in the past, I've tended to do "shotgun" style repairs where I will replace capacitors wholesale, mostly with nearly-identical capacitance/voltage/technology specs but of a modern make which often results in better performance for vintage gear as modern capacitors generally do better on ESR and leakage.
    Forgive my ignorance baldengineer, when you replaced the electrolytic capacitors of the C64, I notice you measured leakage current (related with dissipation factor) to determine if the capacitor electrolyte is still healthy.
    I was wondering whether you measured the ESR difference between the old capacitors and the new capacitors, as reduced ESR (to my rather limited knowledge) should improve ripple voltage and frequency response of the capacitor and is the means by which I normally gauge whether an old capacitor would be any good (along with dissipation factor, although I note that that there are only rough guidelines for ESR as that varies from series-to-series so checking datasheets can be useful and sometimes varies quite significantly for different capacitor technologies especially over frequency).
    - Gough
  • baldengineer
    baldengineer over 6 years ago in reply to Gough Lui
    Gough, good catch. Something I should have more clear is that I was only trying to evaluate the health of the capacitor. I was not trying to assess the performance capability of the old capacitors. Thinking about what I said in the video, I can see how it might not sit well with some. I specifically said I was using the leakage measurement to determine the electrolyte's life. While a true statement, I might have said it too definitively.
    Both ESR and leakage current is used by manufacturers to determine end-of-life for the electrolyte. So to be correct, I should have measured both. However, once one parametrically fails, the capacitor is considered end-of-life. I also like that leakage demonstrates both the dielectric's and electrolyte's health in a single measurement. A healthy dielectric will have a low leakage current, and, a healthy electrolyte will stabilize the current quickly.
    All that said, the #1 reason I showed leakage is because it is an easy measurement to make and understand. All you need is a power supply and multimeter. For a video, it was a simple measurement to show. I, like most people, do not have an ESR meter. So to measure ESR, I would have had to use my scope and function generator. Initially, I thought about showing this measurement, but I felt like it slowed down the video too much to explain how it works. (But it is something I want to do a video on at some point.)
    Another reason I skipped measuring the ESR is that I don't have any information on the original specs for the capacitors. I have no idea what a good or bad ESR measurement would be for them. With 30 years of electrolyte development, it is possible there is already an order of magnitude difference between the ESR of the original capacitors and their modern equivalent. One might say the same for leakage, but my experience from looking through old datasheets suggest that 1-5% of the CV has not changed much over time. And in this case, going from memory, the leakage after 5 minutes was in that range for the capacitor I measured.
  • Gough Lui
    Thanks for the reply - I can definitely understand especially if you don't have an ESR meter to hand as it isn't necessarily easy to measure or interpret. In fact, I invested in one pretty early on as I felt it was going to be "useful" but have (admittedly) never attempted to measure leakage current directly in the way you have. Perhaps I should give that one a go someday image.
    - Gough
  • Gough Lui
    - Gough
