The Learning Circuit
  • The Learning Circuit
Documents Toggle Sign Using an SR Flip-Flop -- The Learning Circuit 61
  • Date Created: 21 Oct 2019 6:33 PM Date Created
  • Last Updated Last Updated: 15 Sep 2021 7:24 AM
  • Views 3171 views
The Learning Circuit | element14 presents |  Project Videos
In the last lesson episode, Karen explored SR and JK flip flops. In this episode, Karen uses an SR Flip Flop with Preset and Clear to demonstrate how the inputs affect the outputs. Using that circuit and no additional parts, Karen shows how to use that flip flop to create a toggle circuit. The final project shows how the circuit can be used to create a  Yes/No, Either/Or sign.This circuit is just the beginning. Adding a 555 timer or sensors instead of a button opens the door to the many different ways this circuit can be useful in an everyday item.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
Super Bright White 5mm LED (25 pack)ADAFRUIT2Buy NowBuy Now
Red LED, Through Hole, 5mm, 20 mA, 2.1 VLED Technology1Buy NowBuy Now
LED, Green, Through Hole, T-3 (10mm), 20 mA, 2.2 V, 568 nmKingbright1Buy NowBuy Now
Flip-Flop, 74LS74, D, 13 ns, 33 MHz, 16 mA, DIPTEXAS INSTRUMENTS1Buy NowBuy Now
Prototype Board, Phenolic, 1.6 mm, 45 mm, 91 mm, (2) smallMulticomp1Buy NowBuy Now
Rocker Switch, On-Off, SPST, PanelZF ELECTRONICS1Buy NowBuy Now
Through Hole Resistor, 10 kohm, 250 mW, ± 1%TE Connectivity4Buy NowBuy Now
Through Hole Resistor, 100 ohmMulticomp2Buy NowBuy Now
Through Hole Resistor, 220 ohm, 400 mW, ± 1%Vishay2Buy NowBuy Now
Tactile Switch, 6mm, Black, Tall, 12 VDC, 50mAE-switch4Buy NowBuy Now
Tactile Switch, 12mm, Black, Tall, 24 VDC, 50mAAlcoswitch1Buy NowBuy Now
Hook-up Wire Spool Set - 22AWG Solid Core - 6 x 25 ftAdafruit1Buy NowBuy Now
9V battery snap, flexibleMulticomp1Buy NowBuy Now
Battery, 9 V, PP3, AlkalinePro Elec1Buy NowBuy Now
Linear Voltage Regulator, 7805, Fixed, 10V To 35V In, 5V And 1A Out, TO-220-3ON SEMICONDUCTOR1Buy NowBuy Now
Additional Parts:
Product Name
Super Bright White 5mm LED (25 pack) - PRODUCT ID: 754 - adafruit.com
TLC_61 Resources.zip
  • don’t mosey
  • voltage regulator
  • toggle
  • clear
  • mosey
  • e14presents_makerkaren
  • the learning cir
  • preset
  • the learning circuit
  • sr latch
  • flip-flop
    DAB over 7 years ago +1
    Good explanation of the circuit and options. DAB
