Project14
Project14
Forum Sensors for Finger Motion Detection
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Replies 12 replies
  • Answers 6 answers
  • Subscribers 205 subscribers
  • Views 2785 views
  • finger-motion-detection
  • sensors
  • motion-detection
thinktoday
thinktoday over 6 years ago
Hii, I have been researching about sensors that could detect the motion of fingers,
For Eg: If my finger is at(0,0) and if I move my finger slightly down I need to detect the y-axis movement
As far as I searched, they prefer to use Accelerometer and Gyroscope Sensors, but I could not achieve this... If we could do with these sensors. Kindly suggest some ways to achieve the result...  If not Kindly suggest is any other sensor can help here...
Thanks in advance image
  • hugohu
    hugohu over 6 years ago +3 suggested
    I remember the Pimoroni Skywriter hat for the Raspberry PI- Using Pimoroni's Python API you can read off the positional data (x, y, z) and common gestures like flick left, tap, and double tap. Electrical…
    dougw over 6 years ago in reply to thinktoday +2 suggested
    https://people.ece.cornell.edu/land/courses/ece4760/FinalProjects/s2010/ssc88_egl27/index.html https://www.youtube.com/watch?v=pHyNrYRhvSg Flicktek - Gesture Control https://tenzr.me/ https://www.youtube…
    dougw over 6 years ago +1 suggested
    There are dozens of ways to detect small motion of a finger. A small sample list of technologies would include: a switch, capacitance, inductance, resistance, radar, sonar, a camera, heat, magnetic And…
  • BigG
    0 BigG over 6 years ago
    There's usually two approaches. First is the state what the objective is or what outcome are you hoping for and then evaluate tech options. This involves detailing the outcome or user requirements. The other approach is to have a technology or technique in mind and then find out what its probable uses could be.
    So it sounds like the camera or visual method fails on one of your requirements...  i.e. having to place hands in a certain region for recognition of gestures...
    I would think that the more reliable method of hand and / or finger movement monitoring would require the user to wear a glove.
    Here are two such examples, randomly pulled off from a Google search:
    https://newatlas.com/hand-movement-glove-capture/60732/
    https://advances.sciencemag.org/content/6/19/eaaz8693.full
    EDIT... I include a PDF attachment.
    imageSensordevices2015.pdf
    0 dougw over 6 years ago in reply to thinktoday
    https://tenzr.me/
    https://www.youtube.com/watch?v=jOEcsNmTk7g
    https://www.robotshop.com/ca/en/usb-flexible-sensor-glove-kit.html?utm_source=google&utm_medium=surfaces&utm_campaign=su…
    https://www.kickstarter.com/projects/asdffilms/gest-work-with-your-hands?token=4c5da7fd
    Plexus / High-performance VR/AR Gloves
    https://en.wikipedia.org/wiki/Power_Glove
    https://www.ultraleap.com/product/leap-motion-controller/
    Gesture Control Glove | Maestro | POWER IN THE PALM OF YOUR HANDS
    https://mimugloves.com/
