Open Arduino
  • Open Arduino
Open Arduino
Blog Newtonian Arduino based telescope
Join Open Arduino to participate - click to join for free!
  • Author Author: netpack
  • Date Created: 20 Apr 2018 1:26 PM Date Created
  • Views 3925 views
  • Likes 9 likes
  • Comments 11 comments
  • openarduinoch
netpack
netpack
20 Apr 2018
Open Arduino
Enter Your Project for a chance to win a grand prize for the most innovative use of Arduino or a $200 shopping cart! The Birthday Special: Arduino Projects for Arduino Day!
Project14 Home
Monthly Themes
Monthly Theme Poll
Hi, I'm developing an algorithm for the Arduino Mega that controls a Newtonian telescope using the SynScan protocol. Help me make it awesome!imageimageimage
Adding some more info as suggested by Enrico (thank you for your comment).
It reads a text file from the SD Card (containing information about some stars) and makes a data structure with that info allocating it in the Arduino memory.
It then sorts that info using a bubble sort algorithm and allow the user to select a star and it will move the telescope to that location (assuming that the telescope is aligned).
Other options include: Testing the communication with the telescope, obtaining info from it (model, version, coordinates, date&time, etc).
I've added a NodeMCU that serves a web interface allowing the control of the telescope from any wi-fi enabled device and I'm also trying to add a GPS module so it could be able to set the location, date&time auto-magically.
    balearicdynamics over 8 years ago +3
    sounds an interesting project. I suppose that to be helpful you should post more than just some images. Enrico
  • netpack
    netpack over 8 years ago in reply to balearicdynamics +3
    Hi Enrico, thank you for your comment. So elaborating: It reads a text file from the SD Card (containing information about some stars) and makes a data structure with that info allocating it in the Arduino…
  • aspork42
    aspork42 over 8 years ago +3
    That is so cool! I'll bet you could add a 6 axis accelerator and GPS module and it can self-align.
    balearicdynamics over 8 years ago in reply to netpack
    I stay in touch following your project, I am curious of how you manage the positioning software.
    Thank you (for now image )
    Enrico
    DAB over 8 years ago
    Nice project.
    You have a good mount, so getting it under computer control should be fairly easy.
  • netpack
    netpack over 8 years ago in reply to aspork42
    Hopefully yes James ;-)
    Thank you.
  • aspork42
  • netpack
    So elaborating:
    It then sorts that info using a bubble sort algorithm and allow the user to select a star and it will move the telescope to that location (assuming that the telescope is aligned). Other options include: Testing the communication with the telescope, obtaining info from it (model, version, coordinates, date&time, etc).
    Let me know if you would like some further info about the setup or the algorithm.
    Thank you once again.
    Cheers.
    Fred.
