      • Japan
      • Vietnam
Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Listening to weather on the radio
  • Author Author: Workshopshed
  • Date Created: 24 Apr 2015 8:44 AM Date Created
  • Views 965 views
  • enchanted_cottage
  • enchanted_objects
  • weather
  • radio
Workshopshed
Workshopshed
24 Apr 2015
When I was younger my Dad used to listen to the shipping forecast on the radio so he could plan his fishing and sailing trips. Given the limited vocabulary it should be possible to use a speech to text processor to convert this to a digital form. But there's also some other systems out there, that should be a bit easier.
If you are in the USA there is the National Weather Radio Specific Area Message Encoding.
NWR SAME provides in a digital form at specific, timely information on the nature and location of a threat to the safety of those most immediately at risk from severe weather or other hazards. Its greatest value is to significantly improve the automatic selection and distribution of messages about events that threaten people and/or property.
NOAA Weather Radio - Using NWR SAME
In Europe there seems to be a similar setup using the DCF77 Time Radio, the "reserved" bits in the signal below are reported to incorporate weather information
DCF77 - Wikipedia, the free encyclopedia
Meteotime.com - Home
I've not seen anyone who's managed to read the weather off either of these systems so I'll unlikely be adding radio as a backup system if my internet goes down but it's interesting to know that these services are there.
Hey I'm British, I'm allowed to be obsessed by the weather!
    DAB over 10 years ago +2
    You are not alone. I grew up in farm country. If you didn't talk about the weather, you were just ignored. DAB
    beacon_dave over 7 years ago +1
    If you've not already seen it, then there are some clues as to decoding the Meteo Time embedded data within the DCF77 signal documented here: meteotime signal decoding from meteotime dcf77 transmitter
    beacon_dave over 7 years ago in reply to beacon_dave +1
    I've heard of 'consuming data', but hardware... ?
    I've heard of 'consuming data', but hardware... ? image
    You are not alone.
