Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog MagicHat - 20 - Adding wisdom
  • Author Author: amgalbu
  • Date Created: 17 Jun 2015 2:04 PM Date Created
  • Views 892 views
  • enchanted_objects
  • quotes
  • nodejs
  • magic_doctor_hat
  • enchanted-objects
amgalbu
amgalbu
17 Jun 2015
Thanks to the Text-To_Speech engine, I can easily add a nice function to the MagicHat: the capability to say wisdom phrases while it's idling
The implementation will be based on a web service that provides quotes as a JSON document
I found a lot of alternatives on www.mashape.com and I selected the quotes service provided by quotbook.com
The URL to invoke to get a new quote has the following format
https://yusufnb-quotes-v1.p.mashape.com/widget/~{search}.json
where {search} is the topic you are interested to get a quote about. To stay on the challenge topic, I will randomly search for the following topics
  • rowling
  • magician
  • harry potter
The quote web service will be queried by theNodeJS application
function getQuote(topic) {
  var http = require('http');
  options = {
    host: 'yusufnb-quotes-v1.p.mashape.com',
    path: '/widget/~' + topic + '.json',
    port: '1338',
    headers: {
       'X-Mashape-Key': '<your mashape key>',
       'Accept': 'application/json"
  callback = function(response) {
  r str = '';
     response.on('data', function(chunk) {
      str += chunk;
    response.on('end', function() {
      console.log(str);
      var obj = JSON.parse(str);
 var mp3url='http://tts-api.com/tts.mp3?q='+encodeURIComponent(obj.quote);
      getMp3(mp3url, filename, function() {
        exec('/usr/bin/madplay -A10 ' + filename);
  req = http.request(options, callback);
  req.end();
Since the Arduino side is aware whether the MagicHat is idling or not, the quote function will be triggered by Arduino itself by sending a new command
Serial1.println("QUOTE");
This command will be parsed by the serial port's data handler
// quote topics
var topics = ['rowling', 'magician', 'harry_potter'];
// generate a random int value between low and high (including limits)
function randomInt (low, high) {
    return Math.floor(Math.random() * (high - low) + low);
// serial port data handler
yunPort.on('data', function(data) {
  //console.log('data ' + data);
  _data = _data + data;
  var eol = _data.indexOf("\r\n");
  if (eol > 0)
    _data = _data.substring(0, eol);
    if (_data.substring(0,5) == "PLAY ")
      console.log("Received command " + _data.substring(0,5)+","+_data.substring(5));
      var text = _data.substring(5);
      _data = "";
      text = text.replace(/ /g, '_');
      var filename = '/mnt/sda1/' + text + '.mp3';
      console.log("Checking file " + filename);
      if (fs.existsSync(filename))
        console.log("Playing file " + filename);
      else
        var mp3url='http://tts-api.com/tts.mp3?q='+encodeURIComponent(text);
    else if (_data.substring(0,5) == "QUOTE")
      getQuote(topics[randomInt(0,topics.length-1)]);
    else
      if (_ws)
        _ws.send(_data);
      _data = "";
  • Workshopshed
    Workshopshed over 11 years ago +1
    This is definitely a good way to use the Yún with the "smarts" on the Linux side where there is plenty of storage and processing capability. I've seen lots of example where the Arduino side is doing way…
  • Workshopshed
    This is definitely a good way to use the Yún with the "smarts" on the Linux side where there is plenty of storage and processing capability. I've seen lots of example where the Arduino side is doing way too much.
