Hats Off Design Challenge
  • Hats Off Design Challenge
Blog Hats Off Mardi Gras - Circle Layout, Wiring & Code (Part 5)
  • Author Author: fearless
  • Date Created: 21 Oct 2014 3:16 AM Date Created
  • Views 975 views
  • mardi_gras_hat
  • hats_off
fearless
fearless
21 Oct 2014
I'm finally at the point where I get to put all my NeoPixels into place and get them wired up. The only sensor that I will be using is the photocell. It's purpose is to detect the light levels and turn off the NeoPixel sequence, if the environment is too bright. I had a bit of a problem after soldering the NeoPixels into place, but with Wayne's help, we were able to overcome it.
Here's a video going over my discoveries and progress:
I used the Adafruit NeoPixel strip loop coding with just a few changes. Here is the final code that I will be using:
#include <Adafruit_NeoPixel.h>
#define PIN 0
int photocell = 1;
int photocellReading;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(7, PIN, NEO_GRB + NEO_KHZ800);
void setup() {
  pinMode(photocell, INPUT);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
void loop() {
  //read photocell looking for unlit room
  photocellReading = analogRead(photocell);
  //lighting is dim, run the neopixels
  if(photocellReading < 300){
      colorWipe(strip.Color(255, 0, 0), 0); // Red
      delay(3000);
      colorWipe(strip.Color(0, 0, 255), 0); // Blue
      delay(3000);
      colorWipe(strip.Color(0, 255, 0), 0); // Green
      delay(3000);
      colorWipe(strip.Color(110, 0, 140), 0); // Purple
      delay(3000);
      colorWipe(strip.Color(217, 187, 1), 0); // Gold
      delay(3000);
  }else{
    //lighting is bright, shut down the neopixels
      colorWipe(strip.Color(0,0,0),0);
      delay(5000);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint16_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
  • fearless
    fearless over 11 years ago in reply to e14 Contributor
    Kandy,
    Thank you for the words of encouragement. The code I posted worked great for me, so you should be able to use it, too. This was my first exposure to electronics and I have to say that I'm totally hooked. The "hat" is all finished now, so please have a look at the videos. I hope you like it!
  • fearless
    fearless over 11 years ago in reply to DAB
    Thanks DAB. You're correct, I have been busy with the final assembly. That's why I didn't reply to you quicker. I'm happy to say that I'm done now. Let me know what you think of the final product.
    i am excited to see the finished product; it looks like it's going to be awesome.  i have to say it am most excited that you gave your code.  i hope to play with photo cell someday soon.  Your project is really coming together; good luck!
    Kandy
    DAB over 11 years ago
    Very good update Lori.
    I like the translucent covers for the neopixels.
    They really disperse the LED light over a nice area.
    It looks like you are about ready to do the final assembly.
    Should be an impressive display.
