Rocking Raspberry Pi
  • Rocking Raspberry Pi
Blog Raspberry Pi and Karaoke Machine (Wolfson Pi Installation)
  • Author Author: babusingh9211
  • Date Created: 5 Apr 2014 5:29 PM Date Created
  • Views 879 views
  • rockingraspberrypi
  • raspberrypi
  • rocking_pi
babusingh9211
babusingh9211
5 Apr 2014
Hello everyone,
Last week I posted about the features of the wolfson pi.
But I haven’t posted about the installation and the procedure to use wolfson pi.
Steps to install Wolfson Pi
  1. Download the Wolfson Pi image from http://downloads.element14.com/wolfson/wolfson_3.10_master.zip?COM=DevKitsLearningCenter
  1. Install the SD Card formatter tool from Install the program format the SD formatter.
  2. Run the SD formatter and select the SD card drive and format it with following setting.
  1. Extract the image from Zip file.
  2. Make sure you are using 8GB memory card
  3. Use Win32diskimager and select the image file and write it to the target SD card.
  4. Insert the memory card into the raspberry pi and all step which were discussed earlier to use raspberry pi.
I also find the other way to install wolfson in the raspbian OS.
In this there are steps to building the Wolfson Audio drivers into the kernel on the Raspberry Pi.
I found it useful so I’ve attached the file in the post.
Truly saying I am unable to implement these all as I was busy preparing seminars and working for college project and my slow internet connection. image
But promising I will do as soon as possible.
If you have any problem and query regarding this don’t hesitate to ask I’ll try my best to answer it. If you have any suggestion’ please comment below.
Regards,
Sumit Rai
