Smarter Life
  • Smarter Life
Smarter Life
Blog A Very Compact Christmas Display - Part 011
  • Author Author: COMPACT
  • Date Created: 13 Nov 2013 11:09 AM Date Created
  • Views 759 views
  • Comments 5 comments
  • psoc4
  • psoc_4
  • smarter_life_challenge
  • psoc_4200
  • compact_xmas_display
  • smarter_life
  • psoc
COMPACT
COMPACT
13 Nov 2013
SPIs Like Us.
The PSoC 4 (CY8C41xx and CY8C42xx) comes with a maximum of 4k SRAM.
This is not always enough space for larger dynamic video frame buffers so to address this I have connected a SPI SRAM to give me this breathing space.
Cypress have planned to release two new PSoC 4 families with with more SRAM next year (CY8C44xx and CY8C46xx).
Here is a link to the Roadmap.
http://www.cypress.com/?docID=46178
Pictured above are the first test results of sequential access testing. It proved that my SPI sequential write was successful.
Below are pictures of my initial single byte write and read tests.
I'm not stranger to using SPI SRAMs and FRAMs (FerroElectric RAM) and have used them for many other designs.
They are a versatile device to address particular challenges.
FRAMS have the advantage of being non-volatile but at a price - Their cost.
For a dynamic video frame buffer I don't have a requirement for non-volatility so SRAMs are satisfactory.
The population of the video frame buffer is done programmatically by the PSoC 4 ARM processor.
Beware that different SPI RAM parts have different protocol schemes.
Ensure that you understand their protocols to get them working.
The above are for the MicroChip 23k256 (256kbit) SRAM.
  • COMPACT
    COMPACT over 12 years ago in reply to cy.gul +1
    Gagan, Oh yes please! They will be very much appreciated Many thanks Very Compact
  • COMPACT
    Gagan,
    Oh yes please!
    Many thanks
    Very Compact
  • cy.gul
    cy.gul over 12 years ago
    Monte,
    do you want to try using some Cypress NVSRAMs (Non-Volatile SRAM)? We could get you some samples to play with image
  • vsluiter
    vsluiter over 12 years ago in reply to COMPACT
    Great stuff! I've been using both Agilent and Tektronix MSO scopes, and they've taken days if not weeks from debugging time by their good (serial) trigger modules.
    Another great tool (and value for money) is Saleae's Logic logic analyser. I'm using that one when I can't use one of the scopes, or have to log long times (errors happening once every hour.....)
  • COMPACT
    COMPACT over 12 years ago in reply to DAB
    Hi Don,
    One of my most important occupational tools - My trusty Tek MSO with embedded communications module that supports SPI and I2C.
    It hooks up to my laboratory workstation to enable the transfer of screenshots and captured data amongst other things.
    It's much easier to use than my first 20MHz dual trace analog CRO and logic probe that I used in the 1980's.
    With the PSoC 4 you can create some basic tools on the fly!
    What progress!
    Cheers
    Very Compact
    DAB over 12 years ago
    Hi Monte,
    Good update.
    What software/device are you using to watch the protocol signals on?
    Thanks,
