Smarter Life
  • Smarter Life
Smarter Life
Blog Smight - 230V uC based dimmer - update
  • Author Author: gelmi
  • Date Created: 15 Dec 2013 11:21 PM Date Created
  • Views 810 views
  • psoc4
  • smarter_life_challenge
  • smight
  • smarter_life
gelmi
gelmi
15 Dec 2013
Hi!
I uploaded a movie of working 230V dimmer example.
I am working on the second part of the project lately - voice recognition part based on Raspberry Pi. I had some troubles with recording, processing and recognizing only the part of the sounds that are over some level of noise. That saves a lot of computational power. I believe I got the solution. As soon as I have some example working I will give you a heads-up.
    DAB over 12 years ago in reply to Kilohercas
    Hi Linus,
    I don't know, I still have memories about the time I blew up a laser power supply.
    Big flash, boom, and an entire wire connector disappeared.
    Took me a week to fix it.
  • Kilohercas
    Kilohercas over 12 years ago in reply to DAB
    You should try to make DRSSTC, it runs on 600-800V peaking at 5000A (at least mine does), and all this at 40-100KHz image
    when you will be comfortable with main input image
  • vsluiter
    vsluiter over 12 years ago
    Hey Gelmi,
    Is the flickering visible for you, or is that interference with the samplerate of your camera?
    Good update Gelma.
    I always get nervous when dealing with main power, especially the European mains.
    Digital levels are just fine with me.
