Blog Beyond the Phone - eList
  • Author Author: mcb1
  • Date Created: 14 Mar 2014 5:40 PM Date Created
  • Views 1089 views
  • beyond_the_phone
  • wireless-power
mcb1
mcb1
14 Mar 2014
My idea for this challenge is to produce an "Electronic Shopping List" (eLIST), using a ePaper display and low power controller.
The concept is the device sits on the charger and receives entries to the list using a wireless solution (likely to be Bluetooth initially).
Entries can be added or subtracted using a web server application, that formats and transmits the list contents to the eLIST.
When its time to shop, the eLIST is removed and a charged cell provides energy to the ePaper and low power controller for the day.
Items can be ticked off as shopping progress's.
On return any items not ticked can be added back to the new list.
I intend to use Wyolum's BADGEr http://wyolum.com/projects/badger/ for the initial 'proof of concept', to reduce the construction time.
It a cheap effective device in its own right.
The final hardware may evolve or remain in the prototype form so others can duplicate it easily.
A second use for the display is for messages ie "Home at 5pm" or "Bring in the washing please" (as happens in our house).
These could be updated or changed using the internet and the webserver, and the on-board buttons.
Using feedback from the transmitter, the webserver will know if the display is present so it can report success or not to the message poster.
Polling the device can provide updates if the 'task' has been completed.
This concept could be a means to send messages to old folks who may not own or operate cellphones.
Both of these will be stretching my software skills, so I anticipate some frustration.
A second area I want to explore is using it to power EL lighting and EL Film.
They have a low power requirement and therefore the transfer efficiency can be dropped to increase the distance.
Increasing the distance may mean you don't have to drill holes or run and hide the wires for some applications.
My thanks to Wurth, Ti and element14 for allowing us to take up this challenge.
edit
My other posts Wireless Challenge .... the other bit eLIST progress 3  eLIST progress 2 , eLIST progress , eLIST - KOBO Touch , 5W Load Schematic
  • kevjose
    kevjose over 12 years ago
    Hi!
    I just went though your blog and realized how startlingly similar our ideas are. Here is my entry for Beyond the Phone ChallengeSmart ID Card
    I look forward to working together and sharing knowledge. While I have not worked with the BADGEr before, I have worked with TFT touchscreens on Arduino, let me know if I can be of any help.
    Kevin
    mcb1 over 12 years ago in reply to DAB
    Thanks
    We have a piece of paper on a magnetic clip on the fridge ... which works unless you don't take it.
    Entering info in is one area that the old pen and paper make it so easy.
    The refresh time on EPD isn't fast, so I'm concerned that using the device to even select from a list may be troublesome ....
    It may be that I go to a touch screen lcd since it really only has to display for one or two hours at most.
    DAB over 12 years ago
    Hi Mark,
    What a great idea.  We use an old fashioned white board pad to jot down grocery items, so something like this would be a nice replacement.
