      • Japan
      • Vietnam
Essentials
  • Essentials
Essentials
Documents Parts Used for element14 Essentials: Sensors I
  • Author Author: joeman
  • Date Created: 18 Aug 2016 8:00 PM Date Created
  • Last Updated Last Updated: 18 Mar 2022 6:27 PM
  • Views 939 views
element14 Learning Center
Sensors I: IC Sensors
Sponsored byimage
Sensors are the interface between the physical world determined by the laws of physics (i.e., mass, acceleration, conductivity, force, magnetic fields, etc.) and the digital world, which interprets the information that sensors provide for use in a wide range of products  - from embedded Internet of Things (IoT) devices to smart phones to even the common household toaster. Because there are so many types of sensors available today, it would be a challenge to discuss all of them in one learning module.  Since electronic design engineers often work with very compact integrated circuits (IC), this learning module will focus on some of the essential IC sensors in use today.
Go to Sensors I Learning Module
Parts Used within the Module
Capacitive Sensors
image image image
Microchip CAP1208-1-A4-TR  8-Channel Capacitive Touch Sensor, QFN Microchip CAP1298-1-A4-TR 8-Channel Capacitive Touch Sensor with Proximity Detection & Signal Guard, QFN Microchip  MTCH102-I/MSMTCH102-I/MS 8-Channel Proximity/Touch Controller MSOP
BuyBuy BuyBuy BuyBuy
Microchip  MTCH101-I/OTMTCH101-I/OT Single-Channel Proximity Detector SOT-23
BuyBuy
Inductive Sensors
Microchip  MCP2036-I/SLMCP2036-I/SL Inductive Sensor Analog Front End Device SOIC
BuyBuy
Current Sensors
image image
Microchip  EMC1701-2-AIZL-TREMC1701-2-AIZL-TR High-Side Current-Sense and Internal 1°C Temperature Monitor MSOP Microchip  PAC1710-1-AIA-TRPAC1710-1-AIA-TR Single High-Side Current Sense Monitor with Power Calculation DFN
BuyBuy BuyBuy
Smoke Detection Sensors
image image image
Microchip  RE46C141S16FRE46C141S16F CMOS Photoelectric Smoke Detector ASIC with Interconnect SOIC Microchip  RE46C166S16FRE46C166S16F CMOS Photoelectric Smoke Detector ASIC with Interconnect Timer Mode and Alarm Memory SOIC Microchip  RE46C180E16FRE46C180E16F CMOS Programmable Ionization Smoke Detector ASIC with Interconnect Timer Mode and Alarm Memory DIP
Microchip  RE46C190S16FRE46C190S16F CMOS Low Voltage Photoelect ric Smoke Detector ASIC with Interconnect and Timer Mode SOIC
BuyBuy
Temperature Sensors
image image image
Microchip MCP9701AT-E/TT  Low-Power Linear Active ThermistorTm IC, SOT-23 Microchip TC77-3.3MCTTR Digital Thermal Sensor with SPITm Interface, SOT-23 Microchip  TC622CPATC622CPA Low Cost Single Trip Point Temperature Sensor DIP
image image image
Microchip  TC74A0-5.0VATTC74A0-5.0VAT Tiny Serial Digital Thermal Sensor TO-220 Microchip MCP98244T-BE/MNY DDR4 DIMM Temperature Sensor with EEPROM for SPD, TDFN Microchip  MCP9904T-2E/9QMCP9904T-2E/9Q Multi-Channel Low-Temperature Remote Diode Sensor VDFN
Micro-Electro-Mechanical Systems (MEMS) Sensors
Microchip  MM7150-AB0MM7150-AB0 MEMS Module Tri-Axis Gyroscope Tri-Axis Accelerometer Tri-Axis Magnetometer 2g Module
BuyBuy
*Trademark. MicrochipRegistered trademark of Microchip Technology Inc.  Other logos, product and/or company names may be trademarks of their respective owners.
  • element14 essentials
  • sensors_i
  • sensors
  • parts used for element14 essentials: sensors i
  • sensors_1
