      • Japan
      • Vietnam
Essentials
  • Essentials
Essentials
Documents Parts Used for element14 Essentials: Circuit Protection I
  • Author Author: pchan
  • Date Created: 26 May 2017 7:33 PM Date Created
  • Last Updated Last Updated: 18 Mar 2022 9:00 PM
  • Views 1540 views
element14 Learning Center
Circuit Protection I: Circuit Breakers
Sponsored byimage
We are living in the age of mechatronics — the intersection of electronics, mechanical engineering and advanced computer control. When electronics design engineers work at their benches, huddled over their breadboards and test equipment, they may increasingly be part of the mechatronic design process, which places value on a cross-functional, interdisciplinary knowledge base. To that end, element14 decided to offer a learning module on circuit breaker essentials for an electronics design engineer community. This learning module will provide you with the essential understanding of circuit breaker protection, arc interruption theory, overcurrent protection, and examples of commonly used circuit breakers in mechatronic product designs.
Go to Circuit Protection I Learning Module
Parts Used within the Module
Residential Low Voltage Circuit Breakers
image image image
CH110 1-Pole Thermal-Magnetic Breaker 120/240VAC 10A CHF120 1-Pole Thermal-Magnetic Breaker 120/240VAC 20A CH120AF 1-Pole FIREGUARD AFCI Circuit Breaker 120/240VAC 20A
BuyBuy BuyBuy BuyBuy
image image
CHFCAF120PN 1-Pole Combination Arc Fault Circuit Breaker 120/240VAC 20A Plug-On Mount CHFGFT120 1-Pole Ground Fault w/Flag Circuit Breaker 120/240VAC 20A
BuyBuy BuyBuyBuyBuy
Industrial Miniature Circuit Breakers
image image image
FAZ-D20/2-NAFAZ-D20/2-NA 2-Pole Thermal-Magnetic Circuit Breaker DINRegistered rail BAB1015V 1-Pole QUICKLAG Circuit Breaker 120/240VAC Bolt-On HQP1010 1-Pole QUICKLAG Circuit Breaker 120/240VAC Plug-On
Molded Case Circuit Breakers
image image
GD3015 3-Pole Circuit Breaker 480VAC/250VDC, C Series G-Frame EGE3015FFGEGE3015FFG 3-Pole Thermal-Magnetic Circuit Breaker 415VAC 15A, G Series EG-Frame DINRegistered rail Panel
BuyBuy BuyBuy
Trip Unit
XTPE065DCS Electronic MMP Trip Unit, Frame D 16-65A
BuyBuy
*Trademark. EatonRegistered is a trademark of Eaton Corp. Other logos, product and/or company names may be trademarks of their respective owners.
  • parts used for element14 essentials: circuit protection
  • circuit_breakers
  • learning_essentials
