      • Japan
      • Vietnam
Essentials
  • Essentials
Essentials
Documents Related Components and Development Boards for Power IV: Smart Power Distribution
  • Author Author: randogless
  • Date Created: 10 Jul 2018 3:57 PM Date Created
  • Last Updated Last Updated: 16 Jul 2018 2:46 PM
  • Views 955 views
element14 Learning Center
Sponsored byimage
The element14 ESSENTIALS of Smart power distribution covers the basics of de-centralized power distribution architectures featuring high-side and low-side smart power switches.  To extend the knowledge covered in the main section of this learning module, this supplementary section was included to discuss the types of related components discussed previously and those that are relevant in prototyping and/or development.
Go to Smart Power Distribution Learning Module
Power PROFET
Power PROFET: Smart High-Side Power Switch, Single Channel
Buy NowBuy Now
The BTS50015-1TAD is a 1.5mΩ single channel, smart high-side power switch, embedded in a PG-TO-263-7-8 package. It contains protective and diagnostic functions, including InfineonRegistered ReverSaveTm functionality (reverse battery protection). The power transistor is built with an N-channel power MOSFET with charge pump. It is specially designed to drive high current loads up to 80 A, such as switched battery couplings, power distribution switches, heaters, and glow plugs for the harsh automotive environment.
image Low standby current
image 3.3V to V S level capable input pin
image Electrostatic discharge protection (ESD)
image Optimized Electromagnetic Compatibility (EMC)
image Logic ground independent from load ground
image Very low leakage current at OUT pin
image Compatible to cranking pulse requirement
image Embedded diagnostic and protection functions
image AEC Qualified
HITFET (Highly Integrated Temperature MOSFET)
HITFET: BTS3256D Smart Low-Side Power Switch, Single Channel, with restart and variable slew rate
Buy NowBuy Now
The BTS3256D is a single channel, low-side power switch in a PG-TO-252-5-11 package, including embedded protective functions. This HITFETTm is designed for automotive and industrial applications.
image Slew rate control by dedicated pin enabling EMC optimized switching or PWM operation
image Maximum switching Frequency 12kHz
image Thermal and overload protection with time-controlled auto restart behavior
image Time and power limited active current limitation
HITFET: AUIPS1042GTR Automotive Q100 Intelligent Power Switch, Dual Channel, Low Side Driver
Buy NowBuy Now
The AUIPS1042GTR is a dual-channel, three-terminal Intelligent Power Switch featuring a low-side MOSFET with over-current, over-temperature, ESD protection, and a drain-to-source active clamp. The AUIPS1042GTR provides efficient protection by turning OFF the power MOSFET when the temperature exceeds 165°C or when the drain current reaches 4.5A. The device restarts once the input is cycled. The avalanche capability is significantly enhanced by the active clamp and covers most inductive load demagnetizations.
image Short-circuit protection
image 12V application
image Slow and fast devices
image Active clamp
image Low current and logic level input
image Optimized turn on/off for EMI
image Diagnostic on the input current
image Over temperature shut own
image Over current shutdown
HIC PROFET (High Current)
HIC-PROFET: BTS500501EGA – Smart High-side Power Switch, Single Channel
Buy NowBuy Now
The BTS50050-1EGA is a single-channel, high-side power switch in a PG-DSO-12-16 package with embedded protective functions, including ReverSave and Infineon INTELLIGENT LATCH. The power transistor is built with an N-channel vertical power MOSFET with a charge pump.
image 3.3 and 5V compatible, ground referenced CMOS compatible inputs
image Very low stand by current
image Stable behavior at under-voltage
image Inverse load current capability
PROFET
PROFET: BTS5030-2EKA Smart High Side Power Switch, Dual Channel
Buy NowBuy Now
The BTS5030-2EKA is a 30 mΩ dual-channel, smart high-side power switch, embedded in a PG-DSO-14-40 exposed Pad package. It is specially designed to drive lamps up to two P21W car bulbs, as well as LEDs.
image Very low stand-by current
image 3.3 V and 5 V compatible logic inputs
image Optimized electromagnetic compatibility
image Very low power DMOS leakage current in OFF state
image Green product (RoHS compliant)
image AEC qualified
PROFET: BTS721L1 Smart High-Side Power Switch
Buy NowBuy Now
The BTS721L1 is a 4-output high-side vertical Power FET Switch with charge pump, ground-referenced CMOS compatible input, and diagnostic feedback. It is monolithically integrated in smart SIPMOSRegistered technology, providing embedded protective functions, under-voltage and overvoltage shutdown with auto-restart and hysteresis.
image Overload protection
image Current limitation
image Thermal shutdown
image Overvoltage protection
image Fast demagnetization of inductive loads
image Reverse battery protection
image Open drain diagnostic output
image Open load detection in ON-state
image Loss of ground and loss of VBB protection
image Electrostatic discharge (ESD) protection
image High voltage capability
Speed PROFET
Speed PROFET: BTF50060-1TEA Smart High-Side Power Switch, Single Channel, High PWM Frequencies
Buy NowBuy Now
Embedded in a PG-TO252-5-11 package, the BTF50060-1TEA is a 6mΩ single channel, smart high-side power switch. It can drive all types of resistive, inductive and capacitive loads. It's suitable for driving loads with PWM frequency from 0Hz (DC operation) up to 33kHz. It can drive valves, coils and motors with in-rush currents up to 60A.
image LCD interface supports up to 24bit LCD display (WXGA)
image Onboard MT41K256M16HA-125:E 1GB DDR3L device
image 4GB EMMC, 32MB QSPI and 32KB EEPROM onboard memory
image Supports Embest 4.3inch and 7inch LCD
image Supports 12-bit camera
image MicroSD card for storage extension
Gate Driver IC
Gate Driver IC: AUIR3200S High Side MOSFET Driver
Buy NowBuy Now
The AUIR3200S is a high-side, Mosfet driver for very low Rdson automotive applications. It offers over-current, overtemperature protection and diagnostic functions. The over-current protection is done by monitoring the Vds voltage, the threshold is programmable by external resistor. The overtemperature protection uses a thermal sensor.
image Bootstrap and charge pump
image Over-temperature shutdown with PTC interface
image Short circuit protection (Vds detection)
image Ground loss protection
image ESD protection
Development boards
Power PROFET: 12V Protected Switch Shield with BTS50015-1TAD for Arduino
Buy NowBuy Now
The 12V protected switch shield for Arduino comes with BTS50015-1TAD, an ultra-low ohmic smart high-side power switch from the Power PROFETTm family.  Designed for relay and fuse replacement in power distribution and junction boxes, Power PROFETTm can drive resistive, capacitive and inductive loads (e.g. heating resistors, filter capacitors, motor, valves and pumps).
image Stand alone and microcontroller mode
image Can be controlled with Arduino compatible microcontroller boards such as the XMCTm microcontroller kits from Infineon
image Easy to use “plug and play”
image Fully configurable for different kind of loads
image Enables quick evaluation of Power PROFETTm for switching loads (BTS50015-1TAD: I NOM = 33 A)
image Fast prototyping for switching applications
HITFETTm+: Low-Side Switch Shield with BTF3050TE for Arduino
Buy NowBuy Now
The SHIELDBTF3050TE Low-Side Switch Shield can control three HITFETTm BTF3050TE low side switches using an Arduino Uno R3, XMC1100 Boot Kit, or similar board. The three low-side switches provide three independent power channels that can be controlled using the input pins. The board is compatible with microcontrollers using the Arduino form factor. The board supports fast and easy prototyping of applications with BTF3050TE.
The BTF3050TE is a 50mΩ high integrated single channel low-side switch. The switch is able to drive resistive, inductive and capacitive loads with a nominal load current of 3A. The power transistor itself is a built in N-channel power MOSFET. The whole device is monolithically integrated with the power MOSFET, driver and protection blocks all in one package. The smart low-side switch provides diagnostic and protection features (e.g. overtemperature, overcurrent). BTF3050TE is qualified and optimized for 12V automotive and industrial applications.
*Trademark. Infineon is a trademark of Infineon Technologies. Other logos, product and/or company names may be trademarks of their respective owners.
  • mosfet
  • infineon
  • power iv: smart power distribution
  • profet
