      • Japan
      • Vietnam
Essentials
  • Essentials
Essentials
Documents Related Components: Variable Frequency AC Drives
  • Author Author: pchan
  • Date Created: 29 Oct 2018 2:26 PM Date Created
  • Last Updated Last Updated: 30 Oct 2018 1:58 PM
  • Views 1018 views
element14 Learning Center
Sponsored byimage
The element14 Essentials of Variable Frequency AC Drives covers the fundamentals of variable frequency drives for speed control of three-phase AC induction motors. To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components.
Go to Learning Module
Variable Frequency Drives
HMX34AG01621-N, 10hp VFD, 16A, 380-480Vac
Buy NowBuy Now
Eaton's H-Max Series VFD has software and hardware designed specifically for the HVAC pump industry. The ultra-efficient DC capacitor and power structure allow the drive to consume less energy. The I/O configuration includes removable terminal blocks. The main control board has six digital IN, two analog IN, one analog OUT, three relay OUT and accepts two additional I/O or communication boards. In addition, the control board has built-in RS-485 and Ethernet communication. In addition, it has an Active Energy Control Algorithm to maximize motor efficiency.
image Integrated 5% DC link choke with Input surge protection—protects against voltage spikes and provides a clean waveform to the motor
image MI/RFI filters standard on all drives—meets EMC Category 2 for commercial applications
image HAND-OFF-AUTO and drive-bypass selector on the keypad—simplifies control
image Onboard RS 485: Modbus, N2, BACnet—meets needs of most communication requirements
image Onboard Ethernet: BACnet/ IP, Modbus/TCP—meets needs of most communication requirements
image Two expansion slots—intended to support additional I/O or communication protocols as necessary
DA1-344D1FB-A20CDA1-344D1FB-A20C Three Phase 1.5 kW VFD 380 to 480 Vac
Buy NowBuy Now
The PowerXLRegistered DA1 variable frequency drives are designed for machinery applications. They have a high-performance processor, safe torque off, multiple Fieldbus protocols including SmartWire-DT, and sensorless vector control.
image Compact, space-saving design
image Industry-leading efficiency delivers energy savings to the customer
image Integrated EMC filters make the unit suitable for commercial and industrial networks
image Brake chopper as standard
image RS-485/ModbusRegistered and CANopenTm as standard
image PID controller as standard
image 200% torque at zero speed
image Designed to run surface mounted (SPM) and rotor in-built (IPM) permanent magnet motors
DG1-32011FB-C21CDG1-32011FB-C21C Variable Frequency Drive PowerXL DG1 Series Three Phase 2.2 kW 208 to 240 Vac
Buy NowBuy Now
The DG1 general purpose drives are part of Eaton's next PowerXL Series of variable frequency drives specifically designed for commercial and industrial applications.  The control module includes standard communication protocols and I/O while still having the modularity to add additional option cards. Eaton's Active Energy Control is also a standard feature on DG1 drives.
image Active energy control, minimizes energy losses by dynamically adjusting V/Hz curve to optimize efficiency
image Onboard communications
image 5% DC link choke
image Conformal coated boards standard
image Graphics LCD keypad display, improves navigation efficiency, local/remote operation from keypad
image Dynamic Motor Regenerative Energy Management
DC1-34024NB-A20NDC1-34024NB-A20N PowerXL DC1 Series Three Phase 11 kW 380 to 480 Vac
Buy NowBuy Now
The PowerXLRegistered DC1 variable frequency drive is designed for machinery applications. The DC1 is compact with only 14 basic parameters, SmartWire-DT connectivity, and ease of mounting and installation. This drive supports single-phase motor applications, and detachable terminal blocks for convenient control wiring.
image Rugged and reliable—175% for 2 s, 50 °C rated
image DIN rail and screw mountable (FS1 and FS2)
image Brake chopper as standard in frames 2 and higher
image Temperature-controlled fan
image PI controller as standard
image SmartWire capability
image Designed for shaded-pole, single-phase motors and permanent split capacitor single-phase motors
MMX34AA014F0-0 VFD M-MAX Series, Sensorless, Three Phase, 10 hp, 380 to 480 Vac
Buy NowBuy Now
Eaton's M-MaxTm Series Sensorless Vector Adjustable Frequency AC Drives are designed for machinery applications. The M-Max product line uses a 32-bit microprocessor and insulated gate bipolar transistors (IGBTs) that provide quiet motor operation, high motor efficiency, and smooth low speed performance. The standard drive includes a digital display, and operating and programming keys on a visually appealing, efficient application programming interface.
image Ease of use—preset application macros, startup wizard, diagnostic capabilities
image Available in the enclosure class IP20 as standard, options for IP21
image Brake chopper as standard in three-phase, applications of frames 2 (FS2) and larger
image RS-485/ModbusRegistered as standard
image Several fieldbus options
*Trademark. Eaton is a trademark of Eaton Corp. Other logos, product and/or company names may be trademarks of their respective owners.
  • related components: variable frequency ac drives
  • ac_drives
    jw0752 over 7 years ago
    The Go to Learning Module Link is broken.
