PCB Design, Prototyping and Production
PCB Blogs Creating a New Symbol in KiCad 10.0 For FireBeetle 2 Esp32C6
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Author Author: electronic-wizard
  • Date Created: 6 Jul 2026 8:32 PM Date Created
  • Views 229 views
  • Likes 10 likes
  • kicad10
  • pcb
  • esp32-c6
  • firebeetle
electronic-wizard
electronic-wizard
6 Jul 2026
Creating a Custom KiCad Symbol for the DFRobot FireBeetle 2 ESP32-C6
When designing a custom carrier PCB around the DFRobot FireBeetle 2 ESP32-C6 v1.2, I discovered that KiCad does not include a built-in symbol for this development board. Instead of using the ESP32-C6-MINI-1 module symbol (which represents the module itself rather than the complete development board), I created a custom symbol that exposes only the header pins available on the FireBeetle.
Step 1: Gather the Pinout
The first step was to obtain the official FireBeetle 2 ESP32-C6 V1.2 pinout from DFRobot's documentation. Since the development board already contains the ESP32-C6 module, power circuitry, USB interface, and other support components, only the header pins needed to be represented in the schematic.
https://wiki.dfrobot.com/dfr1075/#tech_specs
Step 2: Create a Pin Import CSV
FireBeetle_2_ESP32-C6_V1.2_KiCad_PinImport_v2.csv
Rather than manually adding each pin in KiCad, I prepared a CSV file containing:
  • Pin number
  • Pin name
  • Electrical type
  • Pin orientation
  • Pin position
  • Text size
  • Visibility
  • Unit information
The CSV was formatted according to KiCad's Import Pins from CSV specification.
Step 3: Import the Pins
In the KiCad Symbol Editor:
File → New Symbol
After creating an empty symbol:
Tools → Import Pins from CSV
The generated CSV was imported, automatically creating all header pins.
Step 4: Arrange the Symbol
After import, the pins were aligned and spaced evenly around the symbol body.
A rectangle was added to represent the FireBeetle board, and the following symbol properties were configured:
  • Reference: U
  • Value: ESP32-C6 v1.2
  • Description
  • Datasheet URL
Step 5: Verify Electrical Types
Each pin was assigned an appropriate electrical type, such as:
  • Power Input
  • Power Output
  • Input
  • Bidirectional
  • No Connect
These electrical types are important because KiCad's Electrical Rules Check (ERC) uses them to detect wiring mistakes.
Step 6: Save to a Personal Library
Finally, the completed symbol was saved into a custom KiCad library so it can be reused across future projects without recreating it.
Benefits
Creating a custom symbol provides several advantages:
  • Represents the actual FireBeetle development board rather than the underlying ESP32 module.
  • Simplifies schematic design by exposing only usable header pins.
  • Enables clean carrier-board designs.
  • Creates a reusable component for future ESP32-C6 projects.
  • Dakshkanya
    Dakshkanya 1 month ago
    Great walkthrough! The CSV pin import in KiCad 10 is a real time-saver for dev board symbols. One tip — when moving from a carrier PCB like this to a production-ready custom board, replacing the FireBeetle with the bare ESP32-C6-MINI-1 module directly on the PCB saves space and cost significantly. We help teams make exactly that transition at Daksh Kanya: dakshkanya.com/embedded-hardware-design-services/
