Member and Staff Blogs Clem's Stepper Motor Puzzle!
  • Author Author: mayermakes
  • Date Created: 2 Feb 2023 4:07 PM Date Created
  • Views 28529 views
  • Likes 16 likes
  • Comments 43 comments
  • stepper motor
  • puzzle
mayermakes
mayermakes
2 Feb 2023
Developing electronic circuits often feels like solving a puzzle. And solving this puzzle could win you a Multicomp Pro Tablet Oscilloscope!
And while finding the basic application to make an IC do its magic is often quite easy, some questions often remain.
Among the crucial skills of makers and engineers is interpreting a datasheet and this will come in very handy for the following puzzle:
This time we are looking at a staple of the 3d printing and CNC world:  the TMC2130 stepper motor driver.
The photo and schematic show a basic circuit that allows the user to control the movement of a bipolar stepper motor with simple button pushes.
For practical reasons the built circuit has the enable pin(EN) pulled low to activate the circuit.  The Arduino is only used to pass on 12V, 5V and GND to the tmc2130, it has not other connections to the circuit.
Pulling the DIR pin high or low determines the direction of the motor movement.
Pulsing the STEP pin makes the motor move.
But how far does the motor move?
The pins MS1, MS2,MS3 (also known as CFG0,CFG1,CFG2) determine the movement settings; the most widely used configuration is to pull all 3 of them low.
CFG2 determines where to get the voltage reference from. Low level sets it to internal.
The other two pins are much more interesting.
By pulling MS1/CFG0 and MS2/CGF1 low, we set the driver to "Full step," no interpolation and spreadcycle mode.
The most common stepper motors need to do 200 steps per revolution (1,8° angle change per full step).
So for a full rotation we need to press the step button 200 times.
So far so good.
Here is the puzzle:
What happens if you just leave MS1/CFG0 and MS2/CFG1 floating (open) -- how often would you have to push the STEP button for a full rotation?
Or do you think the motor would just not turn at all?
You can find the solution in theory and practice!  We are interested in not only getting the answer right but in seeing the work you did to arrive at this answer.
Tell us if you tried you try it out practically (show us pictures). Or did you study datasheets or video tutorials (share the links you found helpful)?
The member who provides the best detail on how he or she solved the puzzle wins the prize!
Terms and Conditions  Multicomp Pro Tablet Oscilloscope
  • mayermakes
    mayermakes over 3 years ago +4
    https://youtu.be/4N-O1IzRSfc Lets go over the main aspekts of the entries for this competition and find out who is the winner!(TLD:DR skip to the end if you just want to know who won) The element14 community…
    beacon_dave over 3 years ago +3
    The motor won't turn at all as Clem appears to have forgotten to plug the Arduino into a power supply...
  • misaz
    misaz over 3 years ago in reply to mayermakes +3
    Thank you for sending it. Yesterday it arrived and I am playing with it. Fundamental signals are well shown. More details I will post in blog soon.
  • misaz
    misaz over 3 years ago +2
    Hello Element14 community. Today I completed my practical part of this puzzle, and I would like to post my solution. In recent two weeks I did theoretical analysis and two practical experiments. The…
  • mayermakes
    mayermakes over 3 years ago +2
    thank you all for your Entries! it has been a blast seeing how this puzzle challenge played out with a lot of different approaches to finding the solution! We will carefully review all the entries, even…
  • Siana
    Siana over 3 years ago +1
    Trick question! Pololu does not manufacture a TMC2130 breakout. Pololu SKU 2130 is an entirely different thing, a brushed driver module. So that's a Waterrott 2130 stick there. The pins are connected…
  • rsjawale24
    rsjawale24 over 3 years ago in reply to dougw +1
    I would love to do the experimental analysis as theory often needs to be validated using experiments. But I do not have the resources and currently I'm running on a tight schedule. Maybe someone can do…
  • rsjawale24
    rsjawale24 over 3 years ago in reply to misaz +1
    Nice! I always love to see practical applications!
  • mayermakes
    mayermakes over 3 years ago in reply to misaz +1
    Hope you get great use out of your shiny new gadget!
  • rsjawale24
    I would love to do the experimental analysis as theory often needs to be validated using experiments. But I do not have the resources and currently I'm running on a tight schedule.  Maybe someone can do the practical analysis and post it here
  • Siana
    So that's a Waterrott 2130 stick there. The pins are connected straight through according to schematic (https://github.com/watterott/SilentStepStick/raw/master/hardware/SilentStepStick-TMC2130_v20.pdf), MSx to CFGx for 1 to 3. SPI Mode is a jumper normally open (Standalone mode) Chip spec (www.trinamic.com/.../TMC2130_datasheet.pdf): the chip will actually probe the pins and detect them open (chapter 24 datasheet), and set the mode to 16x microstep input, interpolated output, StealthChop. You'll need 16 times as many Step pin toggles as in fullstep mode to complete a revolution.
  • mayermakes
    mayermakes over 3 years ago in reply to dougw
    there could be math, there could be practical testing... I like how this turns out to be a more tricky question than it seems on the surface.
  • mayermakes
    that is one of the aspects practical testing would reveal quicker than theoretical datasheet study...
    dougw over 3 years ago in reply to rsjawale24
    Wouldn't every manual press of the button occur at a standstill moment?
