Member and Staff Blogs Clem's Stepper Motor Puzzle!
  • Author Author: mayermakes
  • Date Created: 2 Feb 2023 4:07 PM Date Created
  • Views 28532 views
  • Likes 16 likes
  • Comments 43 comments
  • stepper motor
  • puzzle
mayermakes
mayermakes
2 Feb 2023
Developing electronic circuits often feels like solving a puzzle. And solving this puzzle could win you a Multicomp Pro Tablet Oscilloscope!
And while finding the basic application to make an IC do its magic is often quite easy, some questions often remain.
Among the crucial skills of makers and engineers is interpreting a datasheet and this will come in very handy for the following puzzle:
This time we are looking at a staple of the 3d printing and CNC world:  the TMC2130 stepper motor driver.
The photo and schematic show a basic circuit that allows the user to control the movement of a bipolar stepper motor with simple button pushes.
For practical reasons the built circuit has the enable pin(EN) pulled low to activate the circuit.  The Arduino is only used to pass on 12V, 5V and GND to the tmc2130, it has not other connections to the circuit.
Pulling the DIR pin high or low determines the direction of the motor movement.
Pulsing the STEP pin makes the motor move.
But how far does the motor move?
The pins MS1, MS2,MS3 (also known as CFG0,CFG1,CFG2) determine the movement settings; the most widely used configuration is to pull all 3 of them low.
CFG2 determines where to get the voltage reference from. Low level sets it to internal.
The other two pins are much more interesting.
By pulling MS1/CFG0 and MS2/CGF1 low, we set the driver to "Full step," no interpolation and spreadcycle mode.
The most common stepper motors need to do 200 steps per revolution (1,8° angle change per full step).
So for a full rotation we need to press the step button 200 times.
So far so good.
Here is the puzzle:
What happens if you just leave MS1/CFG0 and MS2/CFG1 floating (open) -- how often would you have to push the STEP button for a full rotation?
Or do you think the motor would just not turn at all?
You can find the solution in theory and practice!  We are interested in not only getting the answer right but in seeing the work you did to arrive at this answer.
Tell us if you tried you try it out practically (show us pictures). Or did you study datasheets or video tutorials (share the links you found helpful)?
The member who provides the best detail on how he or she solved the puzzle wins the prize!
Terms and Conditions  Multicomp Pro Tablet Oscilloscope
  • mayermakes
    mayermakes over 3 years ago +4
    https://youtu.be/4N-O1IzRSfc Lets go over the main aspekts of the entries for this competition and find out who is the winner!(TLD:DR skip to the end if you just want to know who won) The element14 community…
    beacon_dave over 3 years ago +3
    The motor won't turn at all as Clem appears to have forgotten to plug the Arduino into a power supply...
  • misaz
    misaz over 3 years ago in reply to mayermakes +3
    Thank you for sending it. Yesterday it arrived and I am playing with it. Fundamental signals are well shown. More details I will post in blog soon.
  • misaz
    misaz over 3 years ago +2
    Hello Element14 community. Today I completed my practical part of this puzzle, and I would like to post my solution. In recent two weeks I did theoretical analysis and two practical experiments. The…
  • mayermakes
    mayermakes over 3 years ago +2
    thank you all for your Entries! it has been a blast seeing how this puzzle challenge played out with a lot of different approaches to finding the solution! We will carefully review all the entries, even…
  • Siana
    Siana over 3 years ago +1
    Trick question! Pololu does not manufacture a TMC2130 breakout. Pololu SKU 2130 is an entirely different thing, a brushed driver module. So that's a Waterrott 2130 stick there. The pins are connected…
  • rsjawale24
    rsjawale24 over 3 years ago in reply to dougw +1
    I would love to do the experimental analysis as theory often needs to be validated using experiments. But I do not have the resources and currently I'm running on a tight schedule. Maybe someone can do…
  • rsjawale24
    rsjawale24 over 3 years ago in reply to misaz +1
    Nice! I always love to see practical applications!
  • mayermakes
    mayermakes over 3 years ago in reply to misaz +1
    Hope you get great use out of your shiny new gadget!
  • alex_richter
    alex_richter over 3 years ago
    This reminds me of the good old Day's using my Ramps Shield in my 3D Printer. Sadly i don't have a TMC2130 based Driver, only DRV8826, so i have to stick to the Datasheet.
    From my DRV8826 i remember, that MS1-3 is used to set the microstepping amount. The TMC2130 supports up to 256 Steps, (which is nice, since it will let the Motor run quite smooth) . Typically Microsteps are set from None / Fullstep up to the max supported Steps by doubling the amount of microsteps, (/2, /4, /8, /16, /32, /64,  /128, /256). This is a multiplicator, since each Step is divided by the microstepping.
    Now with connecting MS1-3 High, Low or leaving it open the Microstepping mode is encoded. I had to google around for a bit, since i didn't understand the TMC2130 Datasheet ':/
    I found a very helpful Overview on a website called "microcontrollertutorials".
    https://www.microcontrollertutorials.com/2021/07/tmc2130-stepper-motor-driver-working.html
    Here is a list, which MS Pin Combo stands for which Microstepping setting.
    I found that other than with the DRV8825 only two pins are used for microstepping - > CFG 1 & 2
    Now this riddle asks about leaving CFG0 & 1 floating. It is not clearly defined, what happens to CFG 2, but because it was explained before, that it is typically pulled to GND, i will expect it beeing pulled to GND.
    Looking at the Table, i now check which Microstepping is used, with CFG2 pulled to GND and CFG1 floating.
    The Answer is 1/2.
    If the CFG2 Assumption is wrong,and CFG2 is HIGH the answer would be 1/4 and if floating also 1/16.
    The diver will internally interpolate in all three cases to 256 microsteps, which will make the motor run quite quietly.
    But what is up with CFG0?
    The same website gives a clue. CFG0 apparently sets "CFG0   ---->   Chopper Off Time TOFF (GND=140tclk, VIO=236tclk, OPEN=332tclk)"
    So leaving it Open would set it to 332tclk. What that means i don't know. So i google "TMC2130 CFG0"  and find this website by Trinamic:
    https://www.trinamic.com/technology/motor-control-technology/chopper-modes/.
    My understanding of the Chopper is, that it is part of the constant current driver for the motor coils and is mainly responible of noise reduction and vibration dampening.
    So in this usecase it shouldn't matter at all.
    Ok let's get to the solution part.
    Taking our solution to the selected microstepping mode of 1/2 (halfstep) in account, we can now calculate the Solution.
    I guess the Puzzle also refers to the example Motor of 200Steps / Rev. driven in Halfstep Mode that is 400 Steps / Revolution ->
    you have to press that button 400 times for one rotation.
    Since we don't know the State of CFG2 i'll also provide it's solution. CFG0 connected to 5V will result in 200*4 = 800 and letting it float 200*16 = 3200 steps per Rotation bzw. Clicking that Button for one revolution.
    Useing a higher resolution Motor woth 400 Steps/ Revolution and a 0.9° will double that amount of button clicking.
    Pressing the direction Button will rotate the Motor left or right, so it can either be left alone or has to stay pressed until the revolution is completed.
    Thank you for this puzzle, it's been fun
    Cheers, Alex
  • mayermakes
    mayermakes over 3 years ago in reply to dougw
    that is a very good question and I hope people will think about hat when constructing their answers.
    As you can see in the schematic there is no debounce circuit implemented, just a pullup on each line.
    That has a reason besides simplicity...
    dougw over 3 years ago
    Interesting puzzle, great prize. Normally I would be all over such a puzzle, but I recently won a scope, so I will let others tackle this one. I do have another question though....would switch bounce cause extra motor steps?
