Member's Forum MS-Dos
  • Replies 21 replies
  • Subscribers 633 subscribers
  • Views 2183 views
  • ms-dos
MS-Dos
dwinhold
dwinhold over 10 years ago
Recently we moved and I found an un-opened box of MS-DOS 5.0 upgrade. I don't even recall buying this, but it must have been just before the time Windows was released. Started me thinking.... Should I load this on an old 386?
Dale
    DAB over 10 years ago in reply to jack.chaney56
    Interesting idea.
    I may have to fire up one of my legacy systems to see how well the floppys work.
  • jack.chaney56
    jack.chaney56 over 10 years ago in reply to COMPACT
    Oh, I almost forgot the dual format 1.2M 5 1/4 drives.  If I recall, they didn't have trouble with reading, only with a write/read cycle.  The reason was the voltage level for the head was decreased so the "spot" of data would be smaller.
    Goes to another potential issue, which might just be urban legend. Data degradation on old magnetic media.  Not sure the data image has held up over the decades since DOS 3.1.
  • COMPACT
    COMPACT over 10 years ago in reply to dwinhold
    360K or 1.2M ?
    The disks spin at different rates 300RPM and 360RPM.
    Just remember that 360K disks may not read or write well in a 1.2M drive.
  • dwinhold
    dwinhold over 10 years ago in reply to jack.chaney56
    The boxed DOS I have is on 5 1/4" floppy, luckily my 386 has a 5 1/4" drive.
  • peterjcs23
    peterjcs23 over 10 years ago
    ...and if you get a copy of Xtree Gold you'll be able to run the best File Manager software ever... down hill all the way to Windows 8, (have yet to try 10)...Peter
  • jack.chaney56
    jack.chaney56 over 10 years ago in reply to clem57
    Many cases for the new PCs and laptops is, you need to get an "outboard" 3 1/2" floppy drive to load the OS.  Most of the releases for DOS were not on CD, and most of the new systems don't come with floppy drives. In fact, many of the newer devices are network based, and don't come with CDs either.
  • COMPACT
    About a decade ago when cleaning up I found my pre release developer manuals for Windows 1.0.
    As for MS-DOS - it is hard to beat version 3.3 unless you need drive partitions bigger than 32MB.
    Digital Research had GEM!
  • dwinhold
    I just dusted off the old 386 and will see how well it runs, it has a huge 170mb hard drive.... It is funny how we can't even run computers on that much RAM. This will be fun to go back in time with it. I will have to update what is even on the drive, I haven't got a clue.
  • clem57
    clem57 over 10 years ago in reply to DAB
    Would it be a blast to catalog how many modern machines can run MS/PC-DOS? I wonder a contest of sorts.
    LOL
    Clem
    It should work on the 386 and might work on 486 standard motherboards.
    I think version 5 was a fix just before they came out with MSDOS 6.0 to host Windows 3.1.
    Been a lot of years since then.
