Member's Forum Component storage tips wanted
  • Replies 37 replies
  • Subscribers 596 subscribers
  • Views 9152 views
opalko
opalko over 4 years ago
Hey folks - I am slowly accumulating more and more components. I am working my way through Charles Platt's second book: Make: More Electronics and now have many more IC's I need to find a good way to store. I was using his suggestion from the first book using very sturdy, albeit small, mini-storage boxes like these:
I have filled the 7 or 8 I have like this but have been unable to find any more of the same type.
In the second book he recommends small circular containers within a larger plastic box like this:
which looks similar but better than the storage boxes I have like these:
In these the parts tend to slip from one bin to another.  But the price for that box of circular containers is too expensive for me.
What are your suggestions for storing components? I tried to scour the pictures in John Wiltrout's blog of shop tips articles to see how he stores things but I can't really tell how he does it. Mostly I am looking for IC's, resistors and capacitors at this point.  I like the idea in this instructables  ( https://www.instructables.com/4-DIY-Electronic-Parts-Storage/ )as I have hundreds of similar lidded containers (plastic dog food containers) that I have saved over the years but think they would be too big to store individual components (roughly 9cm x 12cm x 5cm). Should I worry about ESD with a method like this as one of the commenters noted?
Thanks for any ideas!
Robert Opalko
  • Andrew J
    Andrew J over 4 years ago +8
    Quality Street is your friend in this situation:
  • scottiebabe
    scottiebabe over 4 years ago +7
    The only advise I can give is to markup your component bags with a sharpie with the part number in giant text: Electronic distributors design their labels for a factory floor not a proto lab. Lead…
    dougw over 4 years ago +7
    I have several (about 10) multi-drawer cabinets for connectors, switches, and components. When I have too many components for a little drawer I use a plastic shoebox: I also keep MCU modules in shoe…
  • kmikemoo
    kmikemoo over 4 years ago in reply to phoenixcomm
    phoenixcomm  I also prefer the metal housings.  I tripped one time and fell into one of the plastic housing units... resistors and capacitors EVERYWHERE.  It's part of what prompted what I have now.
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to kmikemoo
    yep! I know I a small plastic unit JUNK!! the only problem is the Blue Bins are no longer made. so find them where you can. for a 5x10 there about 50$ on eBay. or about 1$ a draw.
    shabaz over 4 years ago
    Not recommending this necessarily, but just as an idea, personally I have given up organizing through-hole resistors and capacitors, and just throw them into a box, one for Rs and one for Cs, and spend a bit of time finding the right one (or a close one, since usually accuracy isn't needed) when making something on say breadboard.
    However it could be good to also get used to working with surface-mount Rs and Cs too, for instance 0805 sized is large (it is about the same size as 1/8W through-hole resistors, just minus the wires of course) and easy to solder onto perfboard or stripboard. For surface-mount Rs and Cs, it is convenient to buy a book of the components, or store in small envelopes (e.g. florist card envelopes) in a record card storage box. Although I have not purchased it (I have a different set), I thought this set of Rs and Cs looked very good for the price, it comes in a book so it is already organized.
    • Vote Up +5 Vote Down
  • kmikemoo
    kmikemoo over 4 years ago in reply to shabaz
    shabaz   That IS a nice set.  GAA!!!!! You make it hard to keep my "Buy cool stuff" problem in check. JoyJoy   We'll see how long I can resist.
  • Andrew J
    • Vote Up +8 Vote Down
  • opalko
    opalko over 4 years ago in reply to Andrew J
    Do you have dividers inside those?
  • Andrew J
    Andrew J over 4 years ago in reply to opalko
    No, stuff just goes in.
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to opalko
    LOL Wow would you look at tis!!
  • javagoza
    javagoza over 4 years ago in reply to Andrew J
    I use these for cables and small tools.
  • scottiebabe
    Electronic distributors design their labels for a factory floor not a proto lab. Lead free and ROHS are in larger text than the actual component value.
    Then I just keep the components in a clear plastic box by component type.
    • Vote Up +7 Vote Down
