Member's Forum introduction new member
  • Replies 21 replies
  • Subscribers 594 subscribers
  • Views 4397 views
  • lcd display
  • microcontrollers
hazard
hazard over 3 years ago
hi every one, I'm new on the community, first I wanna thanks for the project.
I'm start work with embedded systems, directation to  microcontroller, preferenced atmel (atmega 328p).
I allready have started with 328p and on lcd 40x02 with st7066 driver.
if any one can help me or give a force, I have some sub-routine work fine.
one more time thanks
    Jan Cumps over 3 years ago in reply to hazard +2
    Sitronix left, Hitachi old mid Hitachi newer right Here's a link to my port of the driver: https://github.com/jancumps/hercules_libraries/tree/master/lcd To map code to flowchart. Line 164…
  • beacon_dave
    beacon_dave over 3 years ago in reply to hazard +1
    A while ago Atmel produced a short training series on the AVR based around the Atmel Xplained Mini ATmega328P dev board. Getting Started with AVR https://www.youtube.com/watch?v=UMi6lg563BA&list=PLtQdQmNK_0DRhBWYZ32BEILOykXLpJ8tP…
    Jan Cumps over 3 years ago in reply to genebren +1
    I ported this driver to other controllers and a linux device. I also did it without Arduino. But I used their code as a starting point. In your case, the Arduino driver is already targeted to your controller…
    0 genebren over 3 years ago in reply to hazard
    I can not imagine that the format of the commands should ever change depending on the 4/8bit mode.  Sometimes it is helpful to look at the specification of other chips that are listed as compatible.  Here is a link to a compatible chip that might help you figure out the issues.
    https://www.sparkfun.com/datasheets/LCD/HD44780.pdf
    Good luck.
    0 Jan Cumps over 3 years ago in reply to genebren
    In your case, the Arduino driver is already targeted to your controller. Taking the Arduino code and removing the Arduino specifics should be a doable exercise.
    You have a library that's known to work with the display. And you remove the flavour that you don't want in your code.
    0 genebren over 3 years ago in reply to Jan Cumps
    This is a very good point.  Working from a know good starting point (existing library), allows you to see an example of how to write your standalone software.  Also, if you have an Arduino, you can write a simple program to control the LCD, proving that it is functional.
  • hazard
    0 hazard over 3 years ago in reply to genebren
    I have some arduinos, and some times  I test with some library for check if is every thing ok., after tested onvarduido I start "coding" on MCstudio.
    I will check hd44780 data sheet .
    thanks
    I will return with feedback
  • hazard
    0 hazard over 3 years ago in reply to Jan Cumps
    I will check this, thanks
  • hazard
    hello
    I see on the 44780, and we can coclusion they have a mystake on st7066 datasheet, on pag 20, the N and F bit are repositioned, right?
    thanks
    0 Jan Cumps over 3 years ago in reply to hazard
    image image image
    Line 164 of my driver is the very first command in the lowest block:
    0 shabaz over 3 years ago in reply to genebren
    Totally agree. Even if it's a learning exercise to do it from scratch, it is still worthwhile using existing code if possible first, as some sort of testbench, otherwise sometimes many hours can be wasted if the problem is elsewhere too (e.g. bad wiring or if the contrast voltage is physically not set correctly on the appropriate pin).
    0 Jan Cumps over 3 years ago in reply to shabaz
    Yes. Having a working setup that you can look at, probe, ...
    Else, you're always wondering if it is a hardware fault. And that does not help solving software issues.
  • hazard
    hi thanks for your help. we have conclusion that the dataset have a mistake, anyway this only work in one way with , the bit N and F on position DB7 and DB6.
    thanks
