Member's Forum How do you manage "on stock" component on your personal lab?
  • Replies 26 replies
  • Subscribers 595 subscribers
  • Views 4612 views
strb
strb over 3 years ago
I was just wondering, how do you keep track of components on a personal lab?
I started by simply not doing it but pretty quickly found myself searching among an increasing amount of small component bags in search of the most close resistor value or the best op. amp. I have on hand for the job. For general passive components (resistor and capacitor) I've bought a couple of cheap kits but I suppose they were too cheap because values are scattered without an apparent logic (some E12 component, some E24 value, missing E12 values etc...).
I then started tracking available components in a simple Excel table and that for me was a big step forward: I could search any available component at "design stage" without needing to bring out the component box. A couple hours of inventory once saves me from needing to search among bags of component each time I'm designing something or drawing a scheme.
Less than a month ago I switched from Excel to "DB Browser for SQLite". I'm still learning it and using at most basic level but I'm quite pleased with the result even at this early stage.
This is my experience so far and I'm not regretting doing it. What's your experience on this matter? Do you have any hints?
  • baldengineer
    baldengineer over 3 years ago +6
    For personal stock and projects, I tried using all of the various online part-database services. I disliked all of them. Most are highly focused on pulling Octopart data on active ICs. The problem is the…
  • baldengineer
    baldengineer over 3 years ago in reply to markeno +3
    I use one of these for my random strips of parts. Then I place small labels on the "Row" with whatever the part is. https://www.adafruit.com/product/520 You could even put 2 or 3 strips in a single…
  • Andrew J
    Andrew J over 3 years ago in reply to dougw +2
    It’s not a massive commitment recording mechanism is simple and their location is also recorded. When I have a project, I do check what I have in-stock and everything else is ordered. Stuff goes in a project…
    shabaz over 3 years ago in reply to shabaz
    Oh, and I treat some generic discrete semiconductors in category (a) too. I've got plastic trays (conductive ones) with little pots, each one can fit quite a lot of (say) SOT-23 parts, which are my favorite size for them.
  • Andrew J
    It’s not a massive commitment recording mechanism is simple and their location is also recorded.  When I have a project, I do check what I have in-stock and everything else is ordered.  Stuff goes in a project box and once the project is deemed completed, whatever left is then recorded.  I don’t bother recording stuff that gets consumed immediately; I do record, for example, how much heat shrink I used, or wire, connectors etc because these tend to get bought in bulk.  It isn’t a big overhead to keep it up to date, the tedious bit was actually recording my on-hand stuff in the first place.  I suspect it’s that first setup that puts most people off.
    There is an online application called PartsBox that looks pretty useful.
  • baldengineer
    baldengineer over 3 years ago in reply to strb
    I had to think back to when I created this spreadsheet. Originally, I started the spreadsheet as a way to organize what I had. I intended to then create a SQLlite database and import the data.
    One of the issues I was concerned about is how different part types have different key characteristics. So, I decided to do separate tabs to understand how I would build the database's schema.
    After doing that initial inventory step, I realized the spreadsheet was all I actually wanted. Plus, I didn't have to build any UI since all of the data sorting/analysis tools were already there.
    Like many projects, I had all kinda of crazy ideas for how to extend the functionality. And I suppose in the future, I could still move to a small database.
    But after committing to this idea for a year, I'd rather solder stuff instead.
  • strb
    strb over 3 years ago in reply to shabaz
    shabaz said:
    For a home lab, resistor kit books, capacitor kits and so on are great
    I don't have any of those, but I think I will buy some in the near future because as you said they are great. Key point is to be sure to always have enough components and to "refill" when runnning low.
    dougw over 3 years ago in reply to shabaz
    Your (a) method is basically a type of kanban system (from JIT manufacturing). Kanban maintains adequate stock with minimal administrative overhead. I use a modified version of kanban for generic parts - mainly overlaying a more complex decision matrix of when to restock. I don't automatically restock when a low stock level is detected, I decide if I will order immediately or wait until I have a need, based on cost, price breaks and probabilities.
    Your (b) method (database) devolves into a bunch of expedient techniques where some documentation is utilized with built-in search methods, some physical hierarchical organization of bins allows visual physical searches and some pure physical search methods of physical bins. I guess I use all of that for various aspects of my stock to try to minimize the administrative overhead.
  • baldengineer
    FYI. Most distributors will save your cart if you are logged in. So anytime I realize I am low on parts, I either highlight the row in my spreadsheet or add them to a cart right away. (I really like when they let you name the carts!)
    When I remember, I also use the disty's "custom part number" feature to remind myself it is a "STOCK" part. That way, when it shows up randomly on my next order, I have a reminder of why I bought it.
  • markeno
    markeno over 3 years ago
    Recently I have been thinking about SMD storage options for small quantities.  With larger components it is easy enough for me to use various multi compartment bins and labels.  Short strips of SMD parts are so small and take up so little space I don't really have a great option for sorting and storing them.  Certainly tracking what parts I have around is another portion of that.
  • baldengineer
    You could even put 2 or 3 strips in a single row to save space.
    michaelkellett over 3 years ago
    I use an Excel spreadsheet to keep track of parts which are not tightly connected to specific customer projects. Those go in the project box (or boxes.). When a project ends (often only after many years) the parts get re-organised into the genral parts system.
    I have a large number of plastic drawers in several formats for keeping parts.
    Standard Surface mount R's and Cs live in kit books and get topped up from the bulk store kept unsorted in a few different large boxes.
    Some parts (like uPs and FPGAs) which live in big waffle trays or dry packs are kept in larger boxes with labels on the outside.
    I'm being more organised than I used to be and I think I'm spending less time looking for things !
  • Gough Lui
    Gough Lui over 3 years ago
    To probably no surprise to anyone ... I don't keep track of stock at all.
    I just store my parts in boxes or bins where they should be. If I come to a project and find there's not enough, then I'll start my game of substitutions or ordering "way more than I'd ever need" and waiting it out for delivery (often taking advantage of specials and price breaks).
    As it's not really a job, just a hobby, I try not to take things too seriously. I don't need a full-blown stocktake inventory system, sign-in and sign-out of parts, quality management, safe work procedures, etc ... I just don't think I'd have the discipline to keep it up to date even if I had one, as I'd grab a component for a quick trial-and-error substitution and forget to note it down.
    - Gough
