PCB Design, Prototyping and Production
PCB Forum What are your go to PCB connectors?
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Replies 10 replies
  • Subscribers 160 subscribers
  • Views 4290 views
milosrasic98
milosrasic98 over 2 years ago
Hi!
I'm starting to do more and more custom PCB projects, and one thing I still haven't chosen as my go-to is the connectors. For perfboard projects, I love using the 2.54mm Nylon crimp connectors, because you can solder them easily and the cable-side connectors themselves are extremely easy to crimp. Their only problem is that they're rather bulky and are through-hole. Some of the connectors I've been considering are the small JST ones since they're easily acquirable and should be okay for crimping, I remember crimping those connectors a few years back, and there is of course the whole range of Molex Micro/Mini Fit connectors, which I used at work, but the pliers needed for them are, let's just say not budget-friendly. One thing I love about them though, is that there are a lot of different sizes and pin counts.
So my question would be, what are some of your go-to connectors for PCBs, whether that's for powering your PCB, sensor signals, communication, motors and so on.  I would also love to go with the Molex ones if possible if you have any ideas of any pliers that are okay for crimping them without breaking the bank? I'm just not at the point with the projects where I can justify spending that much on crimping pliers.
Milos
    michaelkellett over 2 years ago +2
    Molex PicoBlade connectors are good for wire to board applications. 1.25mm pitch and available in SM or TH board packages. A decent crimp tool is a silly price (> £300) but I've never found a cheap…
  • rsc
    rsc over 2 years ago +1
    dougw over 2 years ago +1
    I also use 0.1" headers unless some peripheral already has some other connector. I use TE Connectivity MTA series of insulation displacement connectors whenever there is a choice because: they make…
  • rsc
  • misaz
    misaz over 2 years ago
    I use 2.54 mm pin headers unless there are specific requirements (like size). In work, we use mostly JST connectors and terminal blocks.
  • vmate
    vmate over 2 years ago
    For low current applications, I like to use JST-GH for low wire count, or JST-SHD for high wire count connectors.
    I prefer JST XA/PA over XH/PH, they have a latch, so cables cannot come loose on their own. For higher currents, just connect a few pins together.
    For high currents, I usually use an XT-30/60/90 connector.
    A decent crimp tool is a silly price (> £300)  but I've never found a cheap one that's any use.
    I buy ready made leads and cut them in half - much cheaper than buying just the wires with terminals pre-crimped (unless you can find them on Amazon.
    These work out at 0.26p per crimped end and you get 2 receptacles - that's about 1/2  the price of buying the wires.
    A new experiment for me is to buy packs of 20 plug/socket pairs from Amazon - very, very cheap.
    • they make more reliable contact than other connectors
    • they are keyed
    • they have retention features
    • they are way faster to assemble than any other connector (I have the tool)
    • they are low cost
  • aswinvenu
    aswinvenu over 2 years ago
    My personal preference is JST connectors. They come in different pitch sizes. If size is a constrain then I would go with FFC/FPC Connectors ( 1mm pitch or 0.5mm pitch)
    shabaz over 2 years ago
    Hi!
    Regarding "since they're easily acquirable and should be okay for crimping", it gets fiddly (and time-consuming) the smaller the connector gets : ) and as you mention, requires expensive crimp tools, so it may be worth just using connectors where you can find ready-made cables easily.
    For larger wire connections, e.g. power connections, I sometimes just end up using screw terminals if it's just 2-3 connections, and also Mini-Fit Jr mainly because they are ultra-cheap (but the crimp tool is expensive : (
  • anniel747
    anniel747 over 2 years ago
    AMP FASTIN-FASTON, AMP Superseal, AMP MCP, AMP MATE-N-LOK, AMP MTA-156, Molex 3191, Molex MLX, Molex Mini-Fit JR, Molex Picoflex, Symtec Tiger Eye TCSD, various TE FPC and various Mill-Max. Also Switchcraft, Mueller, Phoenix, Weidmüller, BlockMaster, Thomas & Betts, Pomona and Ironwood.
  • colporteur
    colporteur over 2 years ago
    I've come to rely on two terminal block style connectors. The component on the left is for small wire and on the right is for larger gauged wire. 2.54 spacing is what I stick to. I was using different spaces and found it caused problems because they may look the same but won't fit the PCB if you get the size wrong.
    The blocks on the left do require a fairly small common blade screw driver to adjust.
  • koudelad
    koudelad over 2 years ago in reply to michaelkellett
    I love these and was able to crimp 1.5 mm pitch connectors (not sure about 1.25) www.engineertools-jp.com/pa092021
